Strange effect when importing DAE model retrieved on the web
Hi all,
I'm trying to enlarge my models database by retrieving models from the 3D warehouse.
As a reference I'm following this tutorial. And the procedure I follow to generate a COLLADA model is the following.
To check the outcome of the procedure, I open the .dae model with Meshlab. And this is what I get!
image description
So, I'm pretty happy with the result!!!
Next, I create a gazebo model in the following steps:
  • go to ~/gazebo/models folder
  • create a folder to store the necessary files (e.g. ./armchair)
  • create model.config and model.sdf files
  • copy the model.dae file in the ./armchair/meshes folder
  • copy the texture images (if any) in the ./armchair/materials/textures/ folder
where the model.config file contains:
<?xml version="1.0"?>
<model>
  <name>armchair</name>
  <version>1.0</version>
  <sdf version="1.5">model.sdf</sdf>
  <author>
    <name>Federico Nardi</name>
    <email>fnardi@dis.uniroma1.it</email>
  </author>
  <description>
  Armchair
  </description>
and the model.sdf:
<?xml version="1.0" ?>
<sdf version="1.5">
  <model name="armchair">
      <pose>0 0 0 0 0 0</pose>
          <mesh>
            <uri>model://armchair/meshes/model.dae</uri>
          </mesh>
          <mesh>
          </mesh>
When I insert the model in gazebo, this is the picture:
image description
As you can see the textures are correctly loaded, but the edges of the model are marked in white!
Can someone please explain me what's happening?
Thanks.
Hi all,
image description
<model>
  <author>
  </author>
  <description>
  Armchair
  </description>
and the model.sdf:
<sdf version="1.5">
          <mesh>
          </mesh>
          <mesh>
          </mesh>
image description
Thanks.
EDIT: @sloretz, here is the model.dae:
https://drive.google.com/open?id=1J5fCXaAUsOCd_KaECSbFKw12EhtSEnID
EDIT 2: @nkoenig, I'm using Gazebo 7.0.0.
Hi all,
image description
<model>
  <author>
  </author>
  <description>
  Armchair
  </description>
and the model.sdf:
<sdf version="1.5">
          <mesh>
          </mesh>
          <mesh>
          </mesh>
image description
Thanks.
https://drive.google.com/a/dis.uniroma1.it/file/d/1amriasNXdOZe8f-K9m1vVqMEiBtLCQrf/view?usp=sharing
https://drive.google.com/a/dis.uniroma1.it/file/d/1TTqAamutCRL5gWq0O1hKtXR-nLJHa6uM/view?usp=sharing
