Gazebo 7, Ambulance model (and other) Invalid mesh filename extension crash
I installed Gazebo 7 and then downloaded models from https://bitbucket.org/osrf/gazebo_models/downloads/and placed them inside ~/.gazebo/models/ (because gazebo refuses to automatically download any models).
Many of the models work just fine but there is a group of them that refuses to be placed in a world and will in result crash gazebo. In the gazebo log it looks like this:
ros@ros-U44SG:~$ gazebo --verbose
Gazebo multi-robot simulator, version 7.0.0
Copyright (C) 2012-2016 Open Source Robotics Foundation.
http://gazebosim.org
[Msg] Waiting for master.
[Msg] Publicized address: 192.168.1.102
[Err] [MeshManager.cc:96] Invalid mesh filename extension[/home/ros/.gazebo/models/ambulance/meshes/ambulance.obj]
[Err] [Visual.cc:2021] Unable to create a mesh from /home/ros/.gazebo/models/ambulance/meshes/ambulance.obj
[Err] [Visual.cc:352] Ogre Error:OGRE EXCEPTION(6:FileNotFoundException): Cannot locate resource /home/ros/.gazebo/models/ambulance/meshes/ambulance.obj in resource group Autodetect or any other group. in ResourceGroupManager::openResource at /build/ogre-1.9-mqY1wq/ogre-1.9-1.9.0+dfsg1/OgreMain/src/OgreResourceGroupManager.cpp (line 756)
[Err] [Visual.cc:353] Unable to create a mesh from /home/ros/.gazebo/models/ambulance/meshes/ambulance.obj
//3x (...)
[Err] [MeshShape.cc:72] Unable to load mesh from file[/home/ros/.gazebo/models/ambulance/meshes/ambulance.obj]
Qt has caught an exception thrown from an event handler. Throwing
exceptions from an event handler is not supported in Qt. You must
reimplement QApplication::notify() and catch all exceptions there.
terminate called after throwing an instance of 'Ogre::FileNotFoundException'
  what():  OGRE EXCEPTION(6:FileNotFoundException): Cannot locate resource /home/ros/.gazebo/models/ambulance/meshes/ambulance.obj in resource group Autodetect or any other group. in ResourceGroupManager::openResource at /build/ogre-1.9-mqY1wq/ogre-1.9-1.9.0+dfsg1/OgreMain/src/OgreResourceGroupManager.cpp (line 756)
ros@ros-U44SG:~$
