gazebo crash when using .png heightmap and Velodyne 3D LIDARs
I'm testing Velodyne high definition 3D LIDARs in gazebo:
roslaunch velodyne_gazebo example.launch
It will load a 16 laser model. And I have already prepared a heightmap following this tutorial . After loading the heightmap(65x65 (pixels), 10mx10m ) I made, gazebo will not responde.
Sometimes the real time foctor will be around 0.3 when I use 1 beam LiDAR.
I think the reason gazebo will crash is that my laptop‘s hardware performance is not good enough.
Are there anyway to continue the simulation with my laptop? or should I use another computer?? Or maybe there is another reason for the crash.
Thanks in advance.
Are there anyway any ways to continue the simulation with my laptop? or should I use another computer?? Or maybe there is another reason for the crash.
Thanks in advance.
It will load a 16 laser model. And I have already prepared a heightmap following this tutorial . After loading the heightmap(65x65 (pixels), 10mx10m 10mx10m, a larger map also results in crash ) I made, gazebo will not responde.
Are there any ways to continue the simulation with my laptop? or should I use another computer?? Or maybe there is another reason for the crash.
Thanks in advance.
It will load a 16 laser model. And I have already prepared a heightmap following this tutorial . After loading the heightmap(65x65 (pixels), 10mx10m, a larger map also results in crash ) I made, gazebo will not responde.
Sometimes the real time foctor will be around 0.3 when I use 1 beam LiDAR. LiDAR in a .png heightmap.
Thanks in advance.
Sometimes the real time foctor will be around 0.3 when I use 1 beam LiDAR in a .png heightmap.
Thanks in advance.
I think the reason gazebo will crash is that rviz takes too much system resource and my laptop‘s hardware performance is not good enough.
Thanks in advance.
It will load a 16 laser model. And I have already prepared a heightmap following this tutorial . After loading inserting the heightmap(65x65 (pixels), 10mx10m, a larger map also results in crash ) I made, gazebo will not responde.
responde. Sim time and real time will stop.
And in rviz, ROS time will stop, but wall time still goes.
Run roswtf, 3 warnings were found:
WARNING The following node subscriptions are unconnected:
 * /gazebo:
   * /gazebo/set_model_state
   * /gazebo/set_link_state
WARNING These nodes have died:
 * spawn_model-4
WARNING No tf messages
Are there any ways to optimize the program to continue the simulation with my laptop? or should I use another computer?? Or maybe there is another reason for the crash.
Thanks in advance.
It will load a 16 laser model. And I have already prepared a heightmap following this tutorial . After inserting the heightmap(65x65 (pixels), 10mx10m, a larger map also results in crash ) I made, gazebo will not responde. Sim time and real time will stop.
 * /gazebo:
 * spawn_model-4
update: I tried using my PC, there is still the same problem.
Thanks in advance.
