failed to Set velocity for joints
I am trying to insert a solidworks model in gazebo. I use sw2urdf and export a urdf file. When i tried to add force and torque to the blade, it works well and the blades rotate in right position, but wenn i try to set velocity for the joints, all the joints are brocken and in wrong position. How can i fix it? image description image description
