C++ subscriber that updates class variable.
I want to control my robot with an object of a class - that class will start subscribers during initialization and automatically update it's class variables. Then I can use getters to get current state of robot. But I have currently problem with receiving the data - the subscriber doesn't work (it worked when I tried with normal example, but not inside class).
If I am right then the callback doesn't work because when I create the class, the C++ code stops and so subscriber stops. Have anybody done something similar? I don't know C++ -> that's why I am binding everything with python that I can use it. Only idea I got is to start a new process while initializing the class and that process should take care of running the subscriber - but I am not sure if it would work and how to do it.
Here part of my code:
#include <string>
#include <pybind11/pybind11.h>
#include <pybind11/stl.h>
#include <gazebo/gazebo_config.h>
#include <gazebo/transport/transport.hh>
#include <gazebo/msgs/msgs.hh>
#include <stdlib.h>
#include <gazebo/gazebo_client.hh>
namespace py = pybind11;
using namespace std;
class Interface {
  public:
    vector<string> _jointVel = {};
  Interface(string robot) {
    gazebo::client::setup();
    gazebo::transport::NodePtr node(new gazebo::transport::Node());
    node->Init();
    cout << "~/" + robot + "/joints_vel" +" setting up \n";
    // Subscriber
    gazebo::transport::SubscriberPtr subJointVel = node->Subscribe("~/" + robot + "/joints_vel", &Interface::cb, this);
  void cb(ConstGzString_VPtr &_msg)
    cout << " omg \n";
    _jointVel.push_back("bla");
    for (int i = 0; i < _msg->data_size(); i++)
      _jointVel.push_back(_msg->data(i));
    for (vector<string>::const_iterator i = _jointVel.begin(); i != _jointVel.end(); ++i)
      cout << *i << ' ';
    cout << " were received values \n";
  vector<string> getJointsVel()
    cout << " getJointsVelFunction \n";
    return _jointVel;
  void finish(){
    // Make sure to shut everything down.
    gazebo::client::shutdown();
PYBIND11_MODULE(publisher, m) {
  py::class_<Interface>(m, "Interface")
    .def(py::init<const string &>())
    .def("getJointsVel", &Interface::getJointsVel);
#include <string>
#include <stdlib.h>
class Interface {
  public:
    node->Init();
    // Subscriber
    cout << " omg \n";
      cout << *i << ' ';
    return _jointVel;
  void finish(){
C++ subscriber inside class that updates class variable.variable
I want to control my robot with an object of a class - that class will start subscribers during initialization and automatically update it's class variables. Then I can use getters to get current state of robot. But I have currently problem with receiving the data - the subscriber doesn't work (it worked when I tried (I tested subscribing to topics with normal example, but not inside class).gazebo tutorial and my publishers work).
Here part is some of my code:
#include <string>
#include <stdlib.h>
class Interface {
  public:
    node->Init();
    // Subscriber
    cout << " omg \n";
      cout << *i << ' ';
    return _jointVel;
  void finish(){
