add sensor in urdf from gazebo model database
Hi, In gazebo, there are already available models (insert tab) which you can simply insert in your scene. I am having trouble with using it with my urdf model.
I want to add velodyne to my robot. But the problem is that i cannot do this. I have tried adding it using this link information http://gazebosim.org/tutorials/?tut=add_laser but NO LUCK as it's for .sdf format models.
  • -- -- I have also tried this approach but i cannot add velodyne using this approach though i have added different sensors using the same underlying concept: http://gazebosim.org/tutorials?tut=ros_gzplugins
Need help with adding available model (velodyne in .sdf) sensor to a urdf robot model...
