Mobile arm simulation behaves strangely when adding ros_control plugin
Greetings. My model combining a simple mobile base with the UR10 acts strangely when I add
<plugin name="ros_control" filename="libgazebo_ros_control.so" />
which is needed for controlling the UR10 joints. The strange behavior is that the UR resists motion. Two examples:
(1) If I publish a large velocity twist to the cmd_vel topic for the differential_drive_controller on the mobile base the two wheels spin quickly but the robot rotates only very slowly.
(2) If I publish a positive z-position to set_model_state, effectively dropping the robot from this height, it falls very slowly to the ground.
The "real time factor" is 1.00 so it's not as if the simulation is running slowly when the plugin is added. When I don't add the plugin the robot arm is floppy but it moves quickly, as one would expect (the base moves it around at the desired rate and it falls as fast as normal). I will look through the husky simulator with UR5 enabled to try to find what is wrong with my robot.
For reference, here is the source (except for ur10.urdf.xacro). The offending gazebo plugin tag is found in models/common.gazebo.xacro.
(2) If I publish a positive z-position to set_model_state, effectively dropping the robot from this height, it falls very slowly to the ground.ground. It falls so slowly that I was easily able to select the area to grab for this screenshot. (The gap between the mobile base and the arm base is normal for the UR10. It's present even with the ur_gazebo ur10.launch simulation.)
image description
(2) If I publish a positive z-position to set_model_state, effectively dropping the robot from this height, it falls very slowly to the ground. It falls so slowly that I was easily able to select the area to grab for this screenshot. (The gap between the mobile base and the arm base is normal for the UR10. It's present even with the ur_gazebo ur10.launch simulation.)
image description
When publishing an arm pose to arm_controller/command the manipulator moves at a reasonable speed relative to its base but the overall mobile robot is still very slow. For example, if I drop it from two meters and publish a manipulator pose the arm moves fine but the entire robot falls very slowly.
which is needed for controlling the UR10 joints. The strange behavior is that the UR mobile robot resists motion. motion (or maybe it's just the mobile base that does this). Two examples:
image description
which is needed for controlling the UR10 joints. The strange behavior is that the mobile robot resists motion (or maybe it's just the mobile base that does this). Two examples:
image description
The "real time factor" is 1.00 so it's not as if the simulation is running slowly when the plugin is added. When I don't add the plugin the robot arm is floppy but it moves quickly, as one would expect (the base moves it around at the desired rate and it falls as fast as normal). The two controllers both seem to be working well. It's just that things overall get weird when I add the arm_controller. If I keep it and remove the differential_drive_controller the strange behavior is still present.
