How to resolve undefined symbol referenced from my plugin for ray sensor?
I've created a Gazebo Plugin that inherits from the RayPlugin type.
class CustomPlugin : public RayPlugin
It compiles just fine (using Gazebo 9), but when I launch Gazebo I get the following error.
[Err] [Plugin.hh:180] Failed to load plugin {path_to_plugin}/libcustom_plugin.so: {path_to_plugin}/libcustom_plugin.so: undefined symbol:
_ZTIN6gazebo9RayPluginE
I am referencing it in my model file like this:
   <plugin name="custom_plugin" filename="libcustom_plugin.so">
      <!--Parameters-->
In my CMakeLists.txt, I am linking like this:
add_library(custom_plugin SHARED plugins/custom_plugin.cpp)
target_link_libraries(custom_plugin ${GAZEBO_LIBRARIES} ${IGNITION-MSGS_LIBRARIES})
I've done two things to ensure that the GAZEBO_PLUGIN_PATH is set correctly. First, I've used the tag in package.xml.
  <export>
    <!-- Other tools can request additional information be placed here -->
    <gazebo_ros plugin_path="${prefix}/lib" gazebo_media_path="${prefix}" gazebo_model_path="${prefix}/models"/>
  </export>
Secondly, I've manually set the variable to reference both the native Gazebo plugins and the lib folder.
export GAZEBO_PLUGIN_PATH=/usr/lib/x86_64-linux-gnu/gazebo-9/plugins:{path_to_ros_package}/devel/lib
I've verified that /usr/lib/x86_64-linux-gnu/gazebo-9/plugins contains libRayPlugin.so. Neither of these two works.
I am at a loss. Any thoughts?
