GetBoundingBox() values not changing after scale in gazebo (using : visual_plugin)
Gazebo ver: 7.0, ROS : Kinetic [Posted in ros.answers, closed and told to post here]
I am using a visual_plugin to get the box corner points, so later while scaling the object to change the color. I run this plugin inside the box model from the sdf file.
Everything loads good, the box points in the beginning are ok, same as defined in sdf, but if I scale the box (Inside Gazebo), the points when I printout > box_points_, remain the same but if I check in Gazebo into the properties of the box, the points are updated (If I use GetWorldPose(), and printout the pose and move the box, it works, the values are updated). How can I get the boundingbox to update the points in the plugin as I scale.
TheBox.sdf
<?xml version="1.0"?>
<sdf version="1.6">
  <world name='default'>
    <model name="TheBox">
    <pose frame=''>30 13.9 3.05 0 0 0.012944</pose>
    <link name="TheBox">
        <gravity>false</gravity>
        <transparency>0.5</transparency>
            <size>18 2.9 6</size>
            <ambient>1 0 0 1</ambient>
            <diffuse>1 0 0 1</diffuse>
            <specular>0.1 0.1 0.1 1</specular>
            <emissive>0 0 0 0</emissive>
        <plugin name="BoxManipulator" filename="libBoxManipulator.so"/>
  </world>
BoxManipulator.cpp
#include "BoxManipulator.h"
void BoxManipulator::Load(gazebo::rendering::VisualPtr _parent, sdf::ElementPtr _sdf) {
    this->world_ = _parent;
    this->scene_ =  gazebo::rendering::get_scene();
    this->box_ = this->scene_->GetVisual("TheBox");
    // Listen to the update event. This event is broadcast every simulation iteration.
    this->update_connection_ = gazebo::event::Events::ConnectPreRender(std::bind(&BoxManipulator::OnUpdate, this));
  void BoxManipulator::OnUpdate() {
    // Box model
    gazebo::math::Vector3 box_origin_ = this->box_->GetWorldPose().pos;
    gazebo::math::Quaternion box_orientation_ = this->box_->GetWorldPose().rot;
    //Update the points
    getBoxPoints();
    //Printout the points
    for (int i = 0; i < box_points_.size(); i++) {
      std::cout << "Box corner points  : [" << i << "] - " << box_points_[i] << std::endl;
    std::cout << std::endl;
    box_points_.clear();
    // //Later So I can change the color of the box, in different scales
    //     ROS_INFO("Box smaller than 1^3");
    //     red_ = 1; green_ = 0;
    //     gazebo::common::Color _color(red_, green_, blue_, alpha_);
    //     this->world_->SetAmbient(_color);
    //     this->world_->SetDiffuse(_color);
  bool BoxManipulator::getBoxPoints(void){
    gazebo::math::Vector3 _buff; box_points_.reserve(8);
    _buff.x = this->box_->GetBoundingBox().min.x; _buff.y = this->box_->GetBoundingBox().min.y; _buff.z = this->box_->GetBoundingBox().min.z;
    box_points_.push_back(_buff);
    _buff.x = this->box_->GetBoundingBox().min.x; _buff.y = this->box_->GetBoundingBox().max.y; _buff.z = this->box_->GetBoundingBox().min.z;
    _buff.x = this->box_->GetBoundingBox().min.x; _buff.y = this->box_->GetBoundingBox().max.y; _buff.z = this->box_->GetBoundingBox().max.z;
    _buff.x = this->box_->GetBoundingBox().min.x; _buff.y = this->box_->GetBoundingBox().min.y; _buff.z = this->box_->GetBoundingBox().max.z;
    _buff.x = this->box_->GetBoundingBox().max.x; _buff.y = this->box_->GetBoundingBox().min.y; _buff.z = this->box_->GetBoundingBox().min.z;
    _buff.x = this->box_->GetBoundingBox().max.x; _buff.y = this->box_->GetBoundingBox().max.y; _buff.z = this->box_->GetBoundingBox().min.z;
    _buff.x = this->box_->GetBoundingBox().max.x; _buff.y = this->box_->GetBoundingBox().max.y; _buff.z = this->box_->GetBoundingBox().max.z;
    _buff.x = this->box_->GetBoundingBox().max.x; _buff.y = this->box_->GetBoundingBox().min.y; _buff.z = this->box_->GetBoundingBox().max.z;
    return true;
  GZ_REGISTER_VISUAL_PLUGIN(BoxManipulator)
BoxManipulator.h
#ifndef ___BOX_MANIPULATOR___
#define ___BOX_MANIPULATOR___
#include <ros/ros.h>
#include <ros/callback_queue.h>
#include <sdf/sdf.hh>
#include <gazebo/math/gzmath.hh>
#include <gazebo/rendering/rendering.hh>
class BoxManipulator : public gazebo::VisualPlugin {
public:
/// \brief Load the model from the sdf
void Load(gazebo::rendering::VisualPtr _parent, sdf::ElementPtr _sdf);
/// \brief Called by the world update start event
virtual void OnUpdate();
private:
/// \brief Pointer to the model
gazebo::rendering::VisualPtr world_;
/// \brief Variable to store the box model
gazebo::rendering::VisualPtr box_;
/// \brief Pointer to the update event connection
gazebo::event::ConnectionPtr update_connection_;
/// \brief get box points
bool getBoxPoints(void);
/// \brief check
bool check(void);
gazebo::rendering::ScenePtr scene_;
double  red_ = 0,
        green_ = 0,
        blue_ = 0,
        alpha_ = 0.5;
std::vector<gazebo::math::Vector3> box_points_;
#endif
