Invalid Mesh File error - "" is not a valid mesh file
When I import a STL model in Gazebo 7 Model Editor I receive the following error:
"" is not a valid mesh file. Please select another file for [visual]
image description
The file has been exported from SolidWorks in ASCII format. I have tried with several models.
Also no link appears in the Model tab
image description
Any suggestions to why I receive this error and how to make the links work?
Setup:
  • Gazebo 7.0 (ROS kinetic)
  • Ubuntu 16.04
image description
image description
Setup:
  • Ubuntu 16.04
Edit 1:
I may have found a bug or two.
Even though the Uri for the STL file is in the text field in the Visual tab, then it gives me the error. If I browse to the STL in the exact same path, then it can now find it again.
Additionally, I noticed that when I go to the Link tab and enter a value for pose and hit Enter key, then it deletes both Uri paths in Visual and Collision.
Change x pose to 0.1 and hit Enter key
image description
Error that the mesh file cannot be found
image description
Uri to the STL is now empty
image description
image description
The file has been exported from SolidWorks in ASCII format. I have tried with several models.models. One model is attached below, rename it from jpg to STL (because of upload requirements).C:\fakepath\table.jpg
image description
Setup:
  • Ubuntu 16.04
Edit 1:
image description
image description
image description
image description
The file has been exported from SolidWorks in ASCII format. I have tried with several models. One model is attached below, rename it from jpg to STL (because of upload requirements).C:\fakepath\table.jpg
image description
Setup:
  • Ubuntu 16.04
Edit 1:
image description
image description
image description
Edit 2:
Added small video with test in from Gazebo 9.0.0. The error appears after hitting the Enter key when setting the pose of the object.
https://goo.gl/9bULYj
