Wheels rotating without any order given
Hello everyone, I know there are a lot of topics about this kind of problems but I read through a lot of them without getting an answer to my problem. So basically, I have a robot which is made of a base_link (collada file, but it's similar to a rectangle), 2 caster wheels to the front and 2 rotating wheels to the back. So what happens when I launch the simulation, the robot rotates around the Z axis without any cmd_vel being applied to the wheel or for or whatever. I'm really lost here guys so I request your help. I also add that when I turn on collisions view on Gazebo, it shows that every part of my robot is in collision, even with the self-collide turned on false, and the floor itslef is also in collision (it's the basic empty world). I join you my xacro file so that you may help me, and thanks everyone for reading to this point. I'm using Gazebo 7.0.
robot.xacro:
<robot name="robot" xmlns:xacro="http://www.ros.org/wiki/xacro">
<xacro:include filename="$(find robot_description)/urdf/robot.gazebo"/> <xacro:include filename="$(find robot_description)/urdf/macros.xacro"/>
<xacro:property name="PI" value="3.1415926535897931"/>
<xacro:property name="chassis_Height" value="0.002"/> <xacro:property name="chassis_Length" value="0.310"/> <xacro:property name="chassis_Width" value="0.240"/> <xacro:property name="chassis_Mass" value="0.375"/>
<xacro:property name="casterRadius" value="0.0075"/> <xacro:property name="casterMass" value="0.2"/>
<xacro:property name="wheelWidth" value="0.03175"/> <xacro:property name="wheelRadius" value="0.03175"/> <xacro:property name="wheelMass" value="0.2"/>
<link name="base_link"/> <link name="chassis_link"> <collision> <origin xyz="0 0 0" rpy="0 0 0"/> <geometry> <mesh filename="package://robot_description/meshes/chassis_milieu.dae"/> </geometry> </collision> <visual> <origin xyz="0 0 0" rpy="0 0 0"/> <geometry> <mesh filename="package://robot_description/meshes/chassis_milieu.dae"/> </geometry> </visual> <inertial> <origin xyz="0 0 0" rpy="0 0 0"/> <mass value="${chassis_Mass}"/> <origin xyz="0 0 0" rpy="0 0 0"/> <box_inertia m="${chassis_Mass}" x="${chassis_Length}" y="${chassis_Width}" z="${chassis_Height}"/> </inertial> </link>
<joint name="base_joint" type="fixed"> <origin xyz="0 0 100" rpy="0 0 0"/> <parent link="base_link"/> <child link="chassis_link"/> </joint>
<wheel lr="left" ty="1"/> <wheel lr="right" ty="-1"/>
<link name="caster_wheel_left"> <collision> <origin xyz="0 0 0" rpy="0 0 0"/> <geometry> <sphere radius="${casterRadius}"/> </geometry> </collision> <visual> <origin xyz="0 0 0" rpy="0 0 0"/> <geometry> <sphere radius="${casterRadius}"/> </geometry> </visual> <inertial> <origin xyz="0 0 0" rpy="0 0 0"/> <mass value="${casterMass}"/> <sphere_inertia m="${casterMass}" r="${casterRadius}"/> </inertial> </link>
<joint name="caster_wheel_left_joint" type="continuous"> <origin xyz="0.15 0.05 ${-casterRadius-chassis_Height/2}" rpy="0 0 0"/> <axis xyz="1 1 1" rpy="0 0 0"/> <parent link="chassis_link"/> <child link="caster_wheel_left"/> </joint>
<link name="caster_wheel_right"> <collision> <origin xyz="0 0 0" rpy="0 0 0"/> <geometry> <sphere radius="${casterRadius}"/> </geometry> </collision> <visual> <origin xyz="0 0 0" rpy="0 0 0"/> <geometry> <sphere radius="${casterRadius}"/> </geometry> </visual> <inertial> <origin xyz="0 0 0" rpy="0 0 0"/> <mass value="${casterMass}"/> <sphere_inertia m="${casterMass}" r="${casterRadius}"/> </inertial> </link>
<joint name="caster_wheel_right_joint" type="continuous"> <origin xyz="0.15 -0.05 ${-casterRadius-chassis_Height/2}" rpy="0 0 0"/> <axis xyz="1 1 1" rpy="0 0 0"/> <parent link="chassis_link"/> <child link="caster_wheel_right"/> </joint> </robot>
robot.gazebo: <robot> <gazebo> <plugin name="differential_drive_controller" filename="libgazebo_ros_diff_drive.so"> <legacymode>false</legacymode> <alwayson>true</alwayson> <updaterate>10</updaterate> <leftjoint>left_wheel_hinge</leftjoint> <rightjoint>right_wheel_hinge</rightjoint> <wheelseparation>${wheelWidth+chassis_Width}</wheelseparation> <wheeldiameter>${wheelRadius}</wheeldiameter> <torque>0</torque> <commandtopic>cmd_vel</commandtopic> <odometrytopic>odom</odometrytopic> <odometryframe>odom</odometryframe> <robotbaseframe>base_link</robotbaseframe> </plugin> </gazebo> </robot>
macros.xacro: <robot>
<macro name="cylinder_inertia" params="m r h"> <inertia ixx="${m*(3*r*r+h*h)/12}" ixy="0" ixz="0" iyy="${m*(3*r*r+h*h)/12}" iyz="0" izz="${m*r*r/2}"/> </macro>
<macro name="box_inertia" params="m x y z"> <inertia ixx="${m*(y*y+z*z)/12}" ixy="0" ixz="0" iyy="${m*(x*x+z*z)/12}" iyz="0" izz="${m*(x*x+z*z)/12}"/> </macro>
<macro name="sphere_inertia" params="m r"> <inertia ixx="${2*m*r*r/5}" ixy="0" ixz="0" iyy="${2*m*r*r/5}" iyz="0" izz="${2*m*r*r/5}"/> </macro>
<macro name="wheel" params="lr tY">
<link name="${lr}_wheel"> <collision> <origin xyz="0 0 0" rpy="0 ${PI/2} ${PI/2}"/> <geometry> <cylinder length="${wheelWidth}" radius="${wheelRadius}"/> </geometry> </collision>
<visual> <origin xyz="0 0 0" rpy="0 ${PI/2} ${PI/2}"/> <geometry> <cylinder length="${wheelWidth}" radius="${wheelRadius}"/> </geometry> </visual>
<inertial> <origin xyz="0 0 0" rpy="0 ${PI/2} ${PI/2}"/> <mass value="${wheelMass}"/> <cylinder_inertia m="${wheelMass}" r="${wheelRadius}" h="${wheelWidth}"/> </inertial> </link>
<gazebo reference="${lr}_wheel"> <mu1 value="1.0"/> <mu2 value="1.0"/> <kp value="1.0"/> <kd value="1.0"/> <fdir1 value="1 0 0"/> </gazebo>
<joint name="${lr}_wheel_hinge" type="continuous"> <parent link="chassis_link"/> <child link="${lr}_wheel"/> <origin xyz="-0.015 ${tY*wheelWidth/2+tY*0.1} 0" rpy="0 0 0"/> <axis xyz="0 1 0" rpy="0 0 0"/> <limit effort="100" velocity="100"/> <joint_properties damping="0.0" friction="0.0"/> </joint> </macro>
robot.xacro:
robot.xacro: <robot name="robot" xmlns:xacro="http://www.ros.org/wiki/xacro">
robot_description)/urdf/robot.gazebo" />
robot_description)/urdf/macros.xacro" /> <xacro:property name="PI" value="3.1415926535897931"/>
value="3.1415926535897931"/> <xacro:property name="chassis_Height" value="0.002"/> <xacro:property name="chassis_Length" value="0.310"/> <xacro:property name="chassis_Width" value="0.240"/> <xacro:property name="chassis_Mass" value="0.375"/>
value="0.375"/> <xacro:property name="casterRadius" value="0.0075"/> <xacro:property name="casterMass" value="0.2"/>
value="0.2"/> <xacro:property name="wheelWidth" value="0.03175"/> <xacro:property name="wheelRadius" value="0.03175"/> <xacro:property name="wheelMass" value="0.2"/>
value="0.2"/> <link name="base_link"/> <!-- Link chassis --> <link name="chassis_link"> name='chassis_link'> <collision> <origin xyz="0 0 0" rpy="0 0 0"/> <geometry> <mesh filename="package://robot_description/meshes/chassis_milieu.dae"/> </geometry> </collision> <visual> <origin xyz="0 0 0" rpy="0 0 0"/> <geometry> <mesh filename="package://robot_description/meshes/chassis_milieu.dae"/> </geometry> </visual> <inertial> <origin xyz="0 0 0" rpy="0 0 0"/> <mass value="${chassis_Mass}"/> <origin xyz="0 0 0" rpy="0 0 0"/> <box_inertia m="${chassis_Mass}" x="${chassis_Length}" y="${chassis_Width}" z="${chassis_Height}"/> </inertial> </link>
</link> <!-- Joint chassis sur base_link --> <joint name="base_joint" type="fixed"> <origin xyz="0 0 100" rpy="0 0 0"/> <!-- The 100 here was to make sure my robot isn't actually conflicting with the floor --> <parent link="base_link"/> <child link="chassis_link"/> </joint>
</joint> <!-- Macro (link+joint) roues --> <wheel lr="left" ty="1"/> tY="1"/> <wheel lr="right" ty="-1"/>
tY="-1"/> <!-- Link roue libre gauche --> <link name="caster_wheel_left"> <collision> <origin xyz="0 0 0" rpy="0 0 0"/> <geometry> <sphere radius="${casterRadius}"/> </geometry> </collision> <visual> <origin xyz="0 0 0" rpy="0 0 0"/> <geometry> <sphere radius="${casterRadius}"/> </geometry> </visual> <inertial> <origin xyz="0 0 0" rpy="0 0 0"/> <mass value="${casterMass}"/> <sphere_inertia m="${casterMass}" r="${casterRadius}"/> </inertial> </link>
</link> <joint name="caster_wheel_left_joint" type="continuous"> <origin xyz="0.15 0.05 ${-casterRadius-chassis_Height/2}" rpy="0 0 0"/> <axis xyz="1 1 1" rpy="0 0 0"/> <parent link="chassis_link"/> <child link="caster_wheel_left"/> </joint>
</joint> <!-- Link roue libre droite --> <link name="caster_wheel_right"> <collision> <origin xyz="0 0 0" rpy="0 0 0"/> <geometry> <sphere radius="${casterRadius}"/> </geometry> </collision> <visual> <origin xyz="0 0 0" rpy="0 0 0"/> <geometry> <sphere radius="${casterRadius}"/> </geometry> </visual> <inertial> <origin xyz="0 0 0" rpy="0 0 0"/> <mass value="${casterMass}"/> <sphere_inertia m="${casterMass}" r="${casterRadius}"/> </inertial> </link>
</link> <joint name="caster_wheel_right_joint" type="continuous"> <origin xyz="0.15 -0.05 ${-casterRadius-chassis_Height/2}" rpy="0 0 0"/> <axis xyz="1 1 1" rpy="0 0 0"/> <parent link="chassis_link"/> <child link="caster_wheel_right"/> </joint> </robot>
</robot> robot.gazebo: <?xml version="1.0"?> <robot> <gazebo> <plugin name="differential_drive_controller" filename="libgazebo_ros_diff_drive.so"> <legacymode>false</legacymode> <alwayson>true</alwayson> <updaterate>10</updaterate> <leftjoint>left_wheel_hinge</leftjoint> <rightjoint>right_wheel_hinge</rightjoint> <wheelseparation>${wheelWidth+chassis_Width}</wheelseparation> <wheeldiameter>${wheelRadius}</wheeldiameter> <legacyMode>false</legacyMode> <alwaysOn>true</alwaysOn> <updateRate>10</updateRate> <leftJoint>left_wheel_hinge</leftJoint> <rightJoint>right_wheel_hinge</rightJoint> <wheelSeparation>${wheelWidth+chassis_Width}</wheelSeparation> <wheelDiameter>${wheelRadius}</wheelDiameter> <torque>0</torque> <commandtopic>cmd_vel</commandtopic> <odometrytopic>odom</odometrytopic> <odometryframe>odom</odometryframe> <robotbaseframe>base_link</robotbaseframe> <commandTopic>cmd_vel</commandTopic> <odometryTopic>odom</odometryTopic> <odometryFrame>odom</odometryFrame> <robotBaseFrame>base_link</robotBaseFrame> </plugin> </gazebo> </robot>
</robot> macros.xacro: <robot>
<?xml version='1.0'?> <robot> <!-- macro pour les inerties --> <macro name="cylinder_inertia" params="m r h"> <inertia ixx="${m*(3*r*r+h*h)/12}" ixy="0" ixz="0" ixy = "0" ixz = "0" iyy="${m*(3*r*r+h*h)/12}" iyz="0" izz="${m*r*r/2}"/> </macro>
iyz = "0" izz="${m*r*r/2}" /> </macro> <macro name="box_inertia" params="m x y z"> <inertia ixx="${m*(y*y+z*z)/12}" ixy="0" ixz="0" ixy = "0" ixz = "0" iyy="${m*(x*x+z*z)/12}" iyz="0" izz="${m*(x*x+z*z)/12}"/> </macro>
iyz = "0" izz="${m*(x*x+z*z)/12}" /> </macro> <macro name="sphere_inertia" params="m r"> <inertia ixx="${2*m*r*r/5}" ixy="0" ixz="0" ixy = "0" ixz = "0" iyy="${2*m*r*r/5}" iyz="0" izz="${2*m*r*r/5}"/> </macro>
iyz = "0" izz="${2*m*r*r/5}" /> </macro> <!-- Macro des roues --> <macro name="wheel" params="lr tY">
tY"> <link name="${lr}_wheel"> <collision> <origin xyz="0 0 0" rpy="0 ${PI/2} ${PI/2}"/> ${PI/2}" /> <geometry> <cylinder length="${wheelWidth}" radius="${wheelRadius}"/> </geometry> </collision>
</collision> <visual> <origin xyz="0 0 0" rpy="0 ${PI/2} ${PI/2}"/> ${PI/2}" /> <geometry> <cylinder length="${wheelWidth}" radius="${wheelRadius}"/> </geometry> </visual>
</visual> <inertial> <origin xyz="0 0 0" rpy="0 ${PI/2} ${PI/2}"/> ${PI/2}" /> <mass value="${wheelMass}"/> <cylinder_inertia m="${wheelMass}" r="${wheelRadius}" h="${wheelWidth}"/> </inertial> </link>
</link> <gazebo reference="${lr}_wheel"> <mu1 value="1.0"/> <mu2 value="1.0"/> <kp value="1.0"/> value="1.0" /> <kd value="1.0"/> value="1.0" /> <fdir1 value="1 0 0"/> </gazebo>
</gazebo> <joint name="${lr}_wheel_hinge" type="continuous"> <parent link="chassis_link"/> <child link="${lr}_wheel"/> <origin xyz="-0.015 ${tY*wheelWidth/2+tY*0.1} 0" rpy="0 0 0"/> 0" /> <axis xyz="0 1 0" rpy="0 0 0"/> 0" /> <limit effort="100" velocity="100"/> <joint_properties damping="0.0" friction="0.0"/> </joint> </macro>
</macro>
robot.xacro: robot.xacro:
<!-- Put here the robot description -->
<xacro:include filename="$(find robot_description)/urdf/robot.gazebo" />
<xacro:include filename="$(find robot_description)/urdf/macros.xacro" />
<link name='chassis_link'>
  <collision>
  <visual>
<wheel lr="left" tY="1"/>
<wheel lr="right" tY="-1"/>
  <collision>
  <visual>
  <collision>
  <visual>
</robot>
robot.gazebo:
<robot>
  <gazebo>
      <torque>0</torque>
</robot>
macros.xacro:
<robot>
  <inertia  ixx="${m*(3*r*r+h*h)/12}" ixy = "0" ixz = "0"
    iyy="${m*(3*r*r+h*h)/12}" iyz = "0"
    izz="${m*r*r/2}"
</macro>
  <inertia  ixx="${m*(y*y+z*z)/12}" ixy = "0" ixz = "0"
    iyy="${m*(x*x+z*z)/12}" iyz = "0"
</macro>
  <inertia  ixx="${2*m*r*r/5}" ixy = "0" ixz = "0"
    iyy="${2*m*r*r/5}" iyz = "0"
    izz="${2*m*r*r/5}"
</macro>
  <collision>
    <origin xyz="0 0 0" rpy="0 ${PI/2} ${PI/2}" />
  <visual>
  <mu1 value="1.0"/>
  <mu2 value="1.0"/>
  <kp  value="1.0" />
  <kd  value="1.0" />
  <origin xyz="-0.015 ${tY*wheelWidth/2+tY*0.1} 0" rpy="0 0 0" />
  <axis xyz="0 1 0" rpy="0 0 0" />
</macro>
