[UUV Simulator] Including robot into a Gazebo world
Hey everyone,
(I'm a beginner to ROS, Gazebo and UUV Simulator) I am doing the tutorial of UUV Simulator and in the section "Configuring the thruster manager for a new vehicle" I am getting the following error when I try to include my vehicle into the world:
baqueiro@baqueiro-Latitude-E6430:~/catkin_ws$ roslaunch baqtronic_description upload.launch
... logging to /home/baqueiro/.ros/log/136ecaac-5522-11e8-9ca6-f01faf1d30a4/roslaunch-baqueiro-Latitude-E6430-12866.log
Press Ctrl-C to interrupt
xacro: Traditional processing is deprecated. Switch to --inorder processing!
To check for compatibility of your document, use option --check-order.
For more infos, see http://wiki.ros.org/xacro#Processing_Order
XML parsing error: not well-formed (invalid token): line 4, column 8
when processing file: /home/baqueiro/catkin_ws/src/baqtronic_description/urdf/snippets.xacro
included from: /home/baqueiro/catkin_ws/src/baqtronic_description/urdf/base.xacro
included from: /home/baqueiro/catkin_ws/src/baqtronic_description/robots/default.xacro
Check that:
 - Your XML is well-formed
 - You have the xacro xmlns declaration: xmlns:xacro="http://www.ros.org/wiki/xacro"
Invalid <param> tag: Cannot load command parameter [robot_description]: command [/opt/ros/kinetic/share/xacro/xacro.py '/home/baqueiro/catkin_ws/src/baqtronic_description/robots/default.xacro' debug:=0 namespace:=baqtronic] returned with code [2].
Param xml is <param command="$(find xacro)/xacro.py '$(find baqtronic_description)/robots/$(arg mode).xacro' debug:=$(arg debug) namespace:=$(arg namespace)" name="robot_description"/>
The traceback for the exception was written to the log file
I'm using ROS Kinetic and Gazebo 9. Can anyone help me? Thanks in advance :)
Hey everyone,
Check that:
Edit: Below the snippet.xacro:
<?xml version="1.0"?>
<robot xmlns:xacro="http://www.ros.org/wiki/xacro">
<xacro:property name="prop_mesh_file" value="file://$(find baqtronic_description)/meshes/propeller.dae"/>
<xacro:macro name="thruster_macro" params="robot_namespace thruster_id *origin">
Dummy link as place holder for the thruster frame,
since thrusters can often be inside the collision geometry
of the vehicle and may cause internal collisions if set otherwise
<link name="${robot_namespace}/thruster_${thruster_id}">
  <visual>
      <mesh filename="${prop_mesh_file}" scale="1 1 1" />
    <mass value="0.001" />
    <inertia ixx="0.000000017" ixy="0.0" ixz="0.0"
           iyy="0.000000017" iyz="0.0"
           izz="0.000000017" />
<!-- Joint between thruster link and vehicle base link -->
<joint name="${robot_namespace}/thruster_${thruster_id}_joint" type="continuous">
  <xacro:insert_block name="origin" />
  <axis xyz="1 0 0" />
  <parent link="${robot_namespace}/base_link" />
  <child link="${robot_namespace}/thruster_${thruster_id}" />
<gazebo>
  <!-- Thruster ROS plugin -->
  <plugin name="${robot_namespace}_${thruster_id}_thruster_model" filename="libthruster_ros_plugin.so">
    <!-- Name of the thruster link -->
    <linkName>${robot_namespace}/thruster_${thruster_id}</linkName>
    <!-- Name of the joint between thruster and vehicle base link -->
    <jointName>${robot_namespace}/thruster_${thruster_id}_joint</jointName>
    <!-- Make the thruster aware of its id -->
    <thrusterID>${thruster_id}</thrusterID>
    <!-- Gain of the input command signal -->
    <gain>1</gain>
    <!-- Maximum allowed input value for the input signal for thruster unit -->
    <clampMax>0</clampMax>
    <!-- Minimum allowed value for the input signal for thruster unit -->
    <clampMin>0</clampMin>
    <!-- Minimum and maximum thrust force output allowed -->
    <thrustMin>0</thrustMin>
    <thrustMax>0</thrustMax>
    Value from 0 to 1 to set the efficiency of the output thrust force
    Default value is 1.0
    <thrust_efficiency>1</thrust_efficiency>
    Value from 0 to 1 to set the efficiency of the propeller as a factor
    to be multiplied to the current value of the state variable at each
    iteration.
    <propeller_efficiency>1</propeller_efficiency>
    Choose one of the propeller dynamics models below for your implementation
    This will describe the dynamic model for the state variable of your thruster unit,
    which can be, e.g., the angular velocity of the propeller.
    <!-- 1) Simple zero-order model -->
    <dynamics>
      <type>ZeroOrder</type>
    </dynamics>
    <!-- 2) First order model -->
    <dynamics>
      <type>FirstOrder</type>
      <timeConstant>0.0</timeConstant>
    </dynamics>
    <!-- 3) Yoerger's nonlinear dynamic model
    For information on the model description:
    [1] D. R. Yoerger, J. G. Cooke, and J.-J. E. Slotine, “The influence of
        thruster dynamics on underwater vehicle behavior and their incorporation
        into control system design,” IEEE Journal of Oceanic Engineering, vol. 15,
        no. 3, pp. 167–178, Jul. 1990.
    <dynamics>
      <type>Yoerger</type>
      <alpha>0.0</alpha>
      <beta>0.0</beta>
    </dynamics>
    <!-- 4) Bessa's nonlinear dynamic model
    [2] Bessa, Wallace Moreira, Max Suell Dutra, and Edwin Kreuzer. "Thruster
        dynamics compensation for the positioning of underwater robotic vehicles
        through a fuzzy sliding mode based approach." ABCM Symposium Series in
        Mechatronics. Vol. 2. 2006.
    <dynamics>
      <type>Bessa</type>
      <Jmsp>0.0</Jmsp>
      <Kv1>0.0</Kv1>
      <Kv2>0.0</Kv2>
      <Kt>0.0</Kt>
      <Rm>0.0</Rm>
    </dynamics>
    Choose one of the model for the steady-state curve describing the
    relationship between the state variable and the output thrust force
    <!-- 1) Basic curve
    Input: x
    Output: thrust
    Function: thrust = rotorConstant * x * abs(x)
    <conversion>
      <type>Basic</type>
      <rotorConstant>0.0</rotorConstant>
    </conversion>
    <!-- 2) Dead-zone nonlinearity described in Bessa, 2006
    Input: x
    Output: thrust
    Function:
    thrust = rotorConstantL * (x * abs(x) - deltaL), if x * abs(x) <= deltaL
    thrust = 0, if deltaL < x * abs(x) < deltaR
    thrust = rotorConstantR * (x * abs(x) - deltaR), if x * abs(x) >= deltaL
    <conversion>
      <type>Bessa</type>
      <rotorConstantL>0.0</rotorConstantL>
      <rotorConstantR>0.0</rotorConstantR>
      <deltaL>0.0</deltaL>
      <deltaR>0.0</deltaR>
    </conversion>
    <!-- 3) Linear interpolation
    If you have access to the thruster's data sheet, for example,
    you can enter samples of the curve's input and output values
    and the thruster output will be found through linear interpolation
    of the given samples.
    <conversion>
      <type>LinearInterp</type>
      <inputValues>0 1 2 3</inputValues>
      <outputValues>0 1 2 3</outputValues>
    </conversion>
<gazebo reference="${robot_namespace}/thruster_${thruster_id}">
  <selfCollide>false</selfCollide>
</xacro:macro>
<xacro:property name="fin_mesh_file" value="file://$(find baqtronic_description)/meshes/fin.dae"/>
<xacro:property name="fin_min_joint_limit" value="${0.0 * d2r}"/> <xacro:property name="fin_max_joint_limit" value="${0.0 * d2r}"/>
<xacro:macro name="fin_macro" params="namespace fin_id *origin"> <joint name="${namespace}/fin${fin_id}_joint" type="revolute"> <limit effort="0" lower="${fin_min_joint_limit}" upper="${fin_max_joint_limit}" velocity="0"/> <xacro:insert_block name="origin"/> <axis xyz="0 0 1"/> <parent link="${namespace}/base_link"/> <child link="${namespace}/fin${fin_id}"/> </joint>
  <link name="${namespace}/fin${fin_id}">
    <visual>
        <mesh filename="${fin_mesh_file}" scale="1 1 1"/>
  <gazebo>
    <plugin name="${namespace}_fin${fin_id}_model" filename="libfin_ros_plugin.so">
        First order dynamics model for the fin joint dynamics,
        replace an appropriate time constant
      <dynamics>
      </dynamics>
        Definition of the lift and drag model, choose ONE of the models
        below according to the model you want to use.
        1) References for the two line lift and drag model:
          [1] https://en.wikipedia.org/wiki/Lift_coefficient
          [2] http://gazebosim.org/tutorials?tut=aerodynamics&cat=plugins
      <liftdrag>
        <type>TwoLines</type>
        <area>${replace here the value for the area of the fin's cross section}</area>
        <fluid_density>0.0</fluid_density>
        <a0>0.0</a0>
        <alpha_stall>0.0</alpha_stall>
        <cla>0.0</cla><!-- ^= 0.244 when using deg -->
        <cla_stall>0.0</cla_stall>
        <cda>0.0</cda>
        <cda_stall>0.0</cda_stall>
      </liftdrag>
        2) Reference for the quadratic lift and drag model:
          [1] Engelhardtsen, Oystein. 3D AUV Collision Avoidance.
              MS thesis. Institutt for teknisk kybernetikk, 2007.
              https://brage.bibsys.no/xmlui/handle/11250/259834
      <liftdrag>
        <type>Quadratic</type>
        <lift_constant>0.0</lift_constant>
        <drag_constant>0.0</drag_constant>
      </liftdrag>
        Further parameters necessary for the lift and drag plugin
      <!-- Current velocity topic -->
      <current_velocity_topic>/hydrodynamics/current_velocity</current_velocity_topic>
      <!-- Name of the correspodent fin link and joint  -->
      <link_name>${namespace}/fin${fin_id}</link_name>
      <joint_name>${namespace}/fin${fin_id}_joint</joint_name>
      <!-- Output topic to publish the current angle of the fin joint -->
      <output_topic>${namespace}/fins/${fin_id}/output</output_topic>
      <input_topic>${namespace}/fins/${fin_id}/input</input_topic>
      <wrench_topic>${namespace}/fins/${fin_id}/wrench_topic</wrench_topic>
</xacro:macro>
</robot>
Hey everyone,
Check that:
Edit: Below the snippet.xacro:my snippets.xacro:
  <visual>
<gazebo>
    <gain>1</gain>
    iteration.
    <dynamics>
    </dynamics>
    <dynamics>
    </dynamics>
    <dynamics>
      <alpha>0.0</alpha>
      <beta>0.0</beta>
    </dynamics>
    <dynamics>
      <type>Bessa</type>
      <Jmsp>0.0</Jmsp>
      <Kv1>0.0</Kv1>
      <Kv2>0.0</Kv2>
      <Kt>0.0</Kt>
      <Rm>0.0</Rm>
    </dynamics>
    <!-- 1) Basic curve
    Input: x
    Output: thrust
    <conversion>
      <type>Basic</type>
    </conversion>
    Input: x
    Output: thrust
    Function:
    <conversion>
      <type>Bessa</type>
    </conversion>
    <conversion>
    </conversion>
</xacro:macro>
    <visual>
  <gazebo>
      <dynamics>
      </dynamics>
      <liftdrag>
        <a0>0.0</a0>
        <cda>0.0</cda>
      </liftdrag>
      <liftdrag>
      </liftdrag>
</xacro:macro>
</robot>
