Only one model plugin receiving subscription data
Hey guys, I am publishing a Vector3 through a world plugin.
This is the code that publishes
namespace gazebo
    class global_wind : public WorldPlugin
        ignition::math::Vector3d wind;
        transport::PublisherPtr pub;
        public: void Load(physics::WorldPtr _parent, sdf::ElementPtr /*_sdf*/)
            gazebo::transport::NodePtr node(new gazebo::transport::Node);
            node->Init(_parent->GetName());
            transport::run();
            pub = node->Advertise<gazebo::msgs::Vector3d>("~/global_wind");
            this->updateConnection = event::Events::ConnectWorldUpdateBegin(std::bind(&global_wind::OnUpdate, this));
        //  gazebo::transport::fini();
        public: void OnUpdate()
            // pub->WaitForConnection();
            wind.Set(2,2,0);
            gazebo::msgs::Vector3d msg;
            gazebo::msgs::Set(&msg, wind);
            pub->Publish(msg);
    GZ_REGISTER_WORLD_PLUGIN(global_wind)
The lines that are commented are causing some problems. The first commented line causes the following error
[Err] [ConnectionManager.cc:611] ConnectionManager is not initialized
[Err] [TransportIface.cc:416] ConnectionManager has not been initialized!
[Err] [Node.cc:125] No namespaces found
The 2nd commented line just makes gazebo hang when launching. Nonetheless, the plugin 'works' when these 2 are commented.
This is the code that sunscribes.
class wind_push : public ModelPlugin
    // Pointer to the model
    math::Vector3 force;
    public: void Load(physics::ModelPtr _parent, sdf::ElementPtr _sdf)
      this->model = _parent;
      // Create our node for communication
      gazebo::transport::NodePtr node(new gazebo::transport::Node());
      node->Init();
      sub = node->Subscribe("/gazebo/default/global_wind", &wind_push::publ, this);
      gazebo::physics::LinkPtr link= model->GetChildLink("link_1");
      link->AddForce(gazebo::math::Vector3(20, 20, 0));
      // simulation iteration.
      this->updateConnection = event::Events::ConnectWorldUpdateBegin(std::bind(&wind_push::OnUpdate, this));
      link->AddForce(force);
    public: void publ(ConstVector3dPtr &_msg)
      std::cout << this->model->GetName();
      force.Set(_msg->x(),_msg->y(),_msg->z());
  GZ_REGISTER_MODEL_PLUGIN(wind_push)
So what's happening here is that I have many models with the above model plugin. The global_wind plugin publishes a global topic, from which wind_push is supposed to get the wind force vector and apply a suitable force. The problem is that only one model is responding to this force. After further debugging, I found out that only the model plugin on THAT model is calling the callback in the subscriber function, while I actually want all of them to be called. Debugging also revealed that all the model plugins are running, executing other parts of the code. I don't understand why this is happening. Thanks!
namespace gazebo
            transport::run();
            wind.Set(2,2,0);
            pub->Publish(msg);
      node->Init();
Edit:I printed the &wind_push::publ variable in the load function, and all model plugins referred to the same address! Shouldn't gazebo be running a seperate instance of the plugin for each model? Another thing I noticed is that the model which responds to the wind is the last model described with the subscriber plugin in the world file. I think that only the last model plugin's callback is being called. Or there's only one callback???
