I want to make the joints of robot rotated at 0, 90, 180, 270 degrees, but it only shows 90 and 270 degrees repeatedly. I output the joint's angle to the terminal, and actually four angles show periodically. However I do the different test, it always skips one element between two array elements. Does anyone know how to solve this problem? Here is my plugin code.
#include <functional>
#include <gazebo/gazebo.hh>
#include <ignition/math/Vector3.hh>
#include <stdio.h>
using namespace std;
namespace gazebo
int count = 0;
float pos[4] = {0, 1.57, 3.14, 4.71};
class ModelPush : public ModelPlugin
this->model = _parent;
this->updateConnection = event::Events::ConnectWorldUpdateBegin(std::bind(&ModelPush::OnUpdate, this));
public: void OnUpdate()
this->model->GetJoint("joint1")->SetPosition(0, pos[count%4]);
this->model->GetJoint("joint1")->>Update();
this->model->GetJoint("joint2")->SetPosition(0, pos[count%4]);
this->model->GetJoint("joint2")->>Update();
cout << fixed << this->model->GetJoint("joint1")->GetAngle(0).Radian() << "\t";
cout << fixed << this->model->GetJoint("joint2")->GetAngle(0).Radian() << "\t" << endl;
count++;
usleep(500000);
GZ_REGISTER_MODEL_PLUGIN(ModelPush)
