gazebo does not load simple model
I created a simple .world file:
<?xml version="1.0"?>
<sdf version="1.4">
    <world name="office">
            <uri>model://sun</uri>
    </world>
My launch file also adds a robot to this world. It launches fine in gazebo, I can see the gray ground plane with grid markings on it and also my robot. image description
Next I created a simple building layout (some walls created using Gazebo's building editor). I saved the building model and added these lines to my .world file:
    <uri>model://car_description/models/tunnel</uri>
    <pose>25 20.2 0 0 0 0</pose>
When I launch the file again, this time it takes ages to launch. I see a 'Preparing your world ...' screen for a long time (~10 mins): image description
and then I see this dark screen:
image description
There are no errors thrown in the terminal. What am I doing wrong?
<sdf version="1.4">
    </world>
image description
Other solutions which I have tried and did not work for me are:
  1. Adding the following code to the package's package.xml
    <export>
       <gazebo_ros gazebo_model_path="${prefix}/models"/>
       <gazebo_ros gazebo_media_path="${prefix}/models"/>
    </export>
  2. Adding the environment variable GAZEBO_MODEL_PATHto my .bashrc file:
    export GAZEBO_MODEL_PATH=/home/my_user/my_catkin_ws/src/
