turtlebot_gazebo segfaults
So I can run roslaunch gazebo_ros empty_world.launch with no problems. But when I run roslaunch turtlebot_gazebo turtlebot_world.launch something is causing gazebo to crash. Here's the output to stdout:
Segmentation fault (core dumped) [gazebo-1] process has died [pid 10070, exit code 139, cmd /opt/ros/kinetic/lib/gazebo_ros/gzserver -e ode /opt/ros/kinetic/share/turtlebot_gazebo/worlds/playground.world __name:=gazebo __log:=/home/thomas/.ros/log/6a98e730-c490-11e8-a58a-7cdd90a0f479/gazebo-1.log]. log file: /home/thomas/.ros/log/6a98e730-c490-11e8-a58a-7cdd90a0f479/gazebo-1*.log
When I try to dig in deeper by looking at the logs I don't get a whole lot more info:
cat /home/thomas/.ros/log/6a98e730-c490-11e8-a58a-7cdd90a0f479/* | grep ERROR [rosmaster.threadpool][ERROR] 2018-09-30 02:09:11,027: Traceback (most recent call last): [rosmaster.threadpool][ERROR] 2018-09-30 12:04:47,260: Traceback (most recent call last): [roslaunch][ERROR] 2018-09-30 12:04:10,934: [gazebo-1] process has died [pid 10070, exit code 139, cmd /opt/ros/kinetic/lib/gazebo_ros/gzserver -e ode /opt/ros/kinetic/share/turtlebot_gazebo/worlds/playground.world __name:=gazebo __log:=/home/thomas/.ros/log/6a98e730-c490-11e8-a58a-7cdd90a0f479/gazebo-1.log]. [roslaunch][ERROR] 2018-09-30 02:09:11,070: [gazebo-1] process has died [pid 2520, exit code 139, cmd /opt/ros/kinetic/lib/gazebo_ros/gzserver -e ode /opt/ros/kinetic/share/turtlebot_gazebo/worlds/playground.world __name:=gazebo __log:=/home/thomas/.ros/log/6a98e730-c490-11e8-a58a-7cdd90a0f479/gazebo-1.log]. [roslaunch][ERROR] 2018-09-30 02:15:46,626: [gazebo-1] process has died [pid 4034, exit code 139, cmd /opt/ros/kinetic/lib/gazebo_ros/gzserver -e ode /opt/ros/kinetic/share/turtlebot_gazebo/worlds/playground.world __name:=gazebo __log:=/home/thomas/.ros/log/6a98e730-c490-11e8-a58a-7cdd90a0f479/gazebo-1.log]. [rosout][ERROR] 2018-09-30 02:15:46,543: Unpause physics service call failed: unable to connect to service: [Errno 111] Connection refused
Oh and also
Traceback (most recent call last): File "/opt/ros/kinetic/lib/gazebo_ros/spawn_model", line 313, in <module> sm.callSpawnService() File "/opt/ros/kinetic/lib/gazebo_ros/spawn_model", line 289, in callSpawnService rospy.wait_for_service('%s/unpause_physics'%(self.gazebo_namespace)) File "/opt/ros/kinetic/lib/python2.7/dist-packages/rospy/impl/tcpros_service.py", line 159, in wait_for_service raise ROSInterruptException("rospy shutdown") rospy.exceptions.ROSInterruptException: rospy shutdown
So it's dying when it tries to call the spawn service. Any help would be most appreciated. I'm really excited to get started using ROS.
