Basic Joint Control Question
Hi everyone,
I'm looking to write a basic joint control plugin. I'm trying to use SetJointPosition to, well, set the joint position. The joint controller can't seem to find the joint.
I believe I'm doing what the API docs, and Gwen's answer tell me to do.
Is there something else I have to do to make the model aware of the joint?
Here's my minimum (not) working example: The plugin:
#include <boost/bind.hpp>
#include <gazebo.hh>
#include <physics/physics.hh>
#include <common/common.hh>
#include <stdio.h>
namespace gazebo
  class SetJoints : public ModelPlugin
      this->model = _parent;
      this->j2_controller = new physics::JointController(model);
      // simulation iteration.
          boost::bind(&SetJoints::OnUpdate, this, _1));
    public: void OnUpdate(const common::UpdateInfo & /*_info*/)
      // Apply a small linear velocity to the model.
      //this->model->SetLinearVel(math::Vector3(.03, 0, 0));
      double angle(3.0);
      std::string j2name("my_joint");
      j2_controller->SetJointPosition(j2name,angle);
    // Pointer to the model
    private: physics::JointController * j2_controller;
  GZ_REGISTER_MODEL_PLUGIN(SetJoints)
The SDF:
<?xml version="1.0" ?>
<sdf version="1.3">
  <world name="default">
    <!-- Ground Plane -->
      <uri>model://sun</uri>
   <model name="box">
   <static>false</static>
      <link name="base_link">
        <pose>0 0 0.5 0 0 0</pose>
            <ixx>1</ixx>
            <iyy>1</iyy>
            <izz>1</izz>
          <mass>1</mass>
      <link name="top_link">
        <pose> 0 0 1.3 0 0 0 </pose>
            <ixx>1</ixx>
            <iyy>1</iyy>
            <izz>1</izz>
          <mass>1</mass>
              <size>.5 .5 .5</size>
            </box>>
            </box>>
      <joint name="my_joint" type="revolute">
        <parent>base_link</parent>
        <child>top_link</child>
        <axis>
        <xyz>0 0 1</xyz>
        </axis>
     <plugin name="set_joints" filename="build/libset_joints.so"/>
  </world>
Hi everyone,
I'm looking to write a basic joint control plugin. I'm trying to use SetJointPosition to, well, set the joint position. The joint controller can't seem to find the joint. After compiling the plugin, running the code gives me an error:
$ gazebo set_joints.sdf
Gazebo multi-robot simulator, version 1.5.0
Copyright (C) 2013 Open Source Robotics Foundation.
http://gazebosim.org
Msg Waiting for master.Gazebo multi-robot simulator, version 1.5.0
Msg Publicized address: 142.103.111.179
Warning [JointController.cc:190] SetJointPosition [my_joint] not found
the last line appears repeatedly.
#include <stdio.h>
namespace gazebo
      double angle(3.0);
The SDF:
<sdf version="1.3">
   <model name="box">
            <ixx>1</ixx>
            <iyy>1</iyy>
            <izz>1</izz>
          <mass>1</mass>
            <ixx>1</ixx>
            <iyy>1</iyy>
            <izz>1</izz>
          <mass>1</mass>
            </box>>
            </box>>
        <axis>
        <xyz>0 0 1</xyz>
        </axis>
  </world>
