X4 laser sensor limited range
After i run command "X4_SENSOR_CONFIG_4=1 roslaunch subt_example team.launch", the range of the laserscan in only coming less than than 1 as also shown by below screenshot: image description This was happening for the X2 robot also when i used command: "X2_SENSOR_CONFIG_3=1 roslaunch subt_example team.launch": image description But after i replaced the sensor part of the planar_lidar.urdf.xacro file with below code the range is coming fine for X2 robot:
<sensor type="ray" name="${name}">
  <pose>0 0 0 0 0 0</pose>
  <visualize>false</visualize>
  <update_rate>40</update_rate>
  <ray>
    <scan>
      <horizontal>
        <samples>720</samples>
        <resolution>1</resolution>
      </horizontal>
    </scan>
    <range>
      <min>0.10</min>
      <max>30.0</max>
      <resolution>0.01</resolution>
    </range>
    <noise>
      <type>gaussian</type>
      <mean>0.0</mean>
      <stddev>0.01</stddev>
    </noise>
  </ray>
   <plugin name="gazebo_ros_planar_lidar" filename="libgazebo_ros_laser.so">
      <topicName>${topic}</topicName>
      <frameName>${name}</frameName>
      <robotNamespace>${robot_namespace}</robotNamespace>
But still the range of X4 laser scan is under 1. I am running system with 8 gb ram, 300 gb free HD, ubuntu 18.04, and ros melodic with gazebo 9 as described in catkin install tutorial of this subt repository. But im not using any dedicated nvidia gpu, i'm using i5 3rd gen intel cpu.
