Gazebo not publishing joint_state topic
Hello, I want to spwan panda robot in gazebo. For that i have made following files:
  1. Here is the launch file for launching gazebo.
  2. Here is the launch file for launching controllers
  3. Here and here are the controllers i have defined.
  4. Here is the robot URDF (generated from moveit setup assistant )
when i launch the panda.launch file(to launch gazebo and controllers) robot is getting spawned in gazebo. When and run rosnode info gazebo command gazebo doesn't seem to be publishing joint_state topic.
