Running multiple Gazebo simulations on one ROS core
Is it possible to run multiple Gazebo simulation with one ROS core and be able to interact with all the simulation (read and sent messages)?
If so, what is needed in order for this to work?
EDIT 1
I have manage to run two simulation by putting
export GAZEBO_MASTER_URI=http://localhost:11346;
before launching the second simulation and launching each simulation in different group.
<?xml version="1.0"?>
<launch>
    <!-- define arguments -->
    <!-- startup gazebo WORLD -->
   <group ns="$(arg group_name)">
        <param name="robot_description"
            command="$(find xacro)/xacro --inorder '$(find robot_gazebo)/launch/upload_robot.xacro'" />
        <node name="urdf_spawner_$(arg group_name)" pkg="gazebo_ros" type="spawn_model" respawn="false" output="screen"
            args="-urdf -model robot_$(arg group_name) -param robot_description -x $(arg robot_x) -y $(arg robot_y) -z $(arg robot_z)"/>
        <include file="$(find robot_control)/launch/$(arg group_name)_control.launch" if="$(eval control)" >
    </group>
</launch>
I need to use the same model. To be sure I made duplicate model and named it according to the group name. I have made separate control launches for both models and set the gazebo_ros_control controllers into different namespaces.
When I launch the first simulation, it loads as normally and all the controllers loads. As soon as I run the second simulation, however, the controllers case to exist in topic list and most only 3 controller topics out of 8 expected appears on rostopic list for the second robot: the 2nd_robot/joint_states and 2nd_robot/left_wheel/command and 2nd_robot/right_wheel/command. Only 1st_robot/joint_states remains for the first robot.
So I have two simulations running with a robot loaded, but I can't control either of the robots. How do I fix this?
EDIT 1
<launch>
    </group>
</launch>
EDIT 1
<launch>
    </group>
</launch>
When I launch the first simulation, it loads as normally and all the controllers loads. As soon as I run the second simulation, however, the controllers case to exist in topic list and only 3 controller topics out of 8 expected appears on rostopic list for the second robot: the 2nd_robot/joint_states and 2nd_robot/left_wheel/command and 2nd_robot/right_wheel/command. Only 1st_robot/joint_states remains for the first robot.
EDIT 2
I have even run each Gazebo simulation on different ROS core using the multimaster-fkie package, so each Gazebo simulation has different GAZEBO_MASTER_URI and ROS_MASTER_URI, yet the behavior is still the same.
EDIT 1
<launch>
    </group>
</launch>
When I launch the first simulation, it loads as normally and all the controllers loads. As soon as I run the second simulation, however, the controllers case to exist in topic list and only 3 controller topics out of 8 expected appears on rostopic list for the second robot: the 2nd_robot/joint_states and 2nd_robot/left_wheel/command and 2nd_robot/right_wheel/command. (EDIT 4: This number of topics for the second robot is actually right, because I'm using the VelocityJointInterface). Only 1st_robot/joint_states remains for the first robot.
EDIT 2
EDIT 1
<launch>
    </group>
</launch>
When I launch the first simulation, it loads as normally and all the controllers loads. As soon as I run the second simulation, however, the controllers case to exist in topic list and only 3 controller topics out of 8 expected appears on rostopic list for the second robot: the 2nd_robot/joint_states and 2nd_robot/left_wheel/command and 2nd_robot/right_wheel/command (EDIT 4: This number of topics for the second robot is actually right, because I'm using the VelocityJointInterface). Only 1st_robot/joint_states remains for the first robot.
So I have two simulations running with a robot loaded, but I can't control either of the robots. robots (EDIT 4: I can control one of the robot, the second). How do I fix this?
EDIT 2
EDIT 1
<launch>
    </group>
</launch>
When I launch the first simulation, it loads as normally and all the controllers loads. As soon as I run the second simulation, however, the controllers case to exist in topic list and only 3 controller topics out of 8 expected appears on rostopic list for the second robot: the 2nd_robot/joint_states and 2nd_robot/left_wheel/command and 2nd_robot/right_wheel/command (EDIT 4: 3: This number of topics for the second robot is actually right, because I'm using the VelocityJointInterface). Only 1st_robot/joint_states remains for the first robot.
So I have two simulations running with a robot loaded, but I can't control either of the robots (EDIT 4: 3: I can control one of the robot, the second). How do I fix this?
EDIT 2
