World doesn't load when I add to sdf a model did with building editor
I'm using Gazebo 9.6.0 and ROS Melodic in Ubuntu 18.04.
I have this launch file:
<launch>
        <arg name="world_name" value="$(find mybot_gazebo)/worlds/odom_bot.world"/>
        <arg name="gui" value="true"/>
</launch>
And this world file:
<?xml version="1.0"?>
<sdf version="1.6">
  <world name="odom_world">
            <uri>model://sun</uri>
    <model name='Closed-room'>
      <pose frame=''>0.776409 -1.81109 0 0 -0 0</pose>
      <link name='Wall_10'>
        <collision name='Wall_10_Collision'>
              <size>0.75 0.15 2.5</size>
          <pose frame=''>0 0 1.25 0 -0 0</pose>
          <surface>
            <contact>
              <ode/>
            </contact>
            <bounce/>
            <friction>
              <torsional>
                <ode/>
              </torsional>
              <ode/>
            </friction>
          </surface>
        <visual name='Wall_10_Visual'>
            <script>
              <name>Gazebo/Grey</name>
            </script>
            <ambient>1 1 1 1</ambient>
          <meta>
            <layer>0</layer>
          </meta>
        <pose frame=''>7 5.3 0 0 -0 3.14159</pose>
        <enable_wind>0</enable_wind>
        <kinematic>0</kinematic>
      <link name='Wall_5'>
        <collision name='Wall_5_Collision'>
              <size>14.5 0.15 2.5</size>
          <surface>
            <contact>
              <ode/>
            </contact>
            <bounce/>
            <friction>
              <torsional>
                <ode/>
              </torsional>
              <ode/>
            </friction>
          </surface>
        <visual name='Wall_5_Visual'>
            <script>
            </script>
          <meta>
            <layer>0</layer>
          </meta>
        <pose frame=''>-0.125 5.3 0 0 -0 0</pose>
      <link name='Wall_7'>
        <collision name='Wall_7_Collision'>
              <size>10.75 0.15 2.5</size>
          <surface>
            <contact>
              <ode/>
            </contact>
            <bounce/>
            <friction>
              <torsional>
                <ode/>
              </torsional>
              <ode/>
            </friction>
          </surface>
        <visual name='Wall_7_Visual'>
            <script>
            </script>
          <meta>
            <layer>0</layer>
          </meta>
        <pose frame=''>-7.3 -0 0 0 -0 -1.5708</pose>
      <link name='Wall_8'>
        <collision name='Wall_8_Collision'>
              <size>14.75 0.15 2.5</size>
          <surface>
            <contact>
              <ode/>
            </contact>
            <bounce/>
            <friction>
              <torsional>
                <ode/>
              </torsional>
              <ode/>
            </friction>
          </surface>
        <visual name='Wall_8_Visual'>
            <script>
            </script>
          <meta>
            <layer>0</layer>
          </meta>
        <pose frame=''>-0 -5.3 0 0 -0 0</pose>
      <link name='Wall_9'>
        <collision name='Wall_9_Collision'>
          <surface>
            <contact>
              <ode/>
            </contact>
            <bounce/>
            <friction>
              <torsional>
                <ode/>
              </torsional>
              <ode/>
            </friction>
          </surface>
        <visual name='Wall_9_Visual'>
            <script>
            </script>
          <meta>
            <layer>0</layer>
          </meta>
        <pose frame=''>7.3 -0 0 0 -0 1.5708</pose>
      <static>1</static>
  </world>
I have added a model (named Closed_room) did with Building Editor, but when I launch it, it doesn't show the model.
If I open the world with Gazebo, without using the launch file, it shows the building.
Do you know why?
<launch>
</launch>
<sdf version="1.6">
          <surface>
            <contact>
              <ode/>
            </contact>
            <bounce/>
            <friction>
              <torsional>
                <ode/>
              </torsional>
              <ode/>
            </friction>
          </surface>
            <script>
            </script>
          <meta>
            <layer>0</layer>
          </meta>
          <surface>
            <contact>
              <ode/>
            </contact>
            <bounce/>
            <friction>
              <torsional>
                <ode/>
              </torsional>
              <ode/>
            </friction>
          </surface>
            <script>
            </script>
          <meta>
            <layer>0</layer>
          </meta>
          <surface>
            <contact>
              <ode/>
            </contact>
            <bounce/>
            <friction>
              <torsional>
                <ode/>
              </torsional>
              <ode/>
            </friction>
          </surface>
            <script>
            </script>
          <meta>
            <layer>0</layer>
          </meta>
          <surface>
            <contact>
              <ode/>
            </contact>
            <bounce/>
            <friction>
              <torsional>
                <ode/>
              </torsional>
              <ode/>
            </friction>
          </surface>
            <script>
            </script>
          <meta>
            <layer>0</layer>
          </meta>
          <surface>
            <contact>
              <ode/>
            </contact>
            <bounce/>
            <friction>
              <torsional>
                <ode/>
              </torsional>
              <ode/>
            </friction>
          </surface>
            <script>
            </script>
          <meta>
            <layer>0</layer>
          </meta>
      <static>1</static>
  </world>
Do you know why?
