drc simulator
Hi I am trying to controll some of the drc robot. How can I give effort commands to the joint and not placement commands tothe PID that is on the joint? Thanks Nachum
drc simulatorIs there a way to control effort/torque in the DRC sim directly
Hi I am trying to controll some of the drc robot. How can I give effort commands to the joint and not placement commands tothe PID that is on the joint? Thanks NachumNachum As said here I put into the launch file and the yaml an effort controller, when i do rostopic list I see the controller but when I give it a command nothing happens.
Any idea?
Hi I am trying to controll control some of the drc robot. How can I give effort commands to the joint and not placement commands tothe PID that is on controlling the joint? Thanks Nachum joint aset point of effort and not a set point of angle?
Thanks
Nachum
Any idea?
Hi I am trying to control some of the drc robot. How can I give to the PID that is controlling the joint aset a set point of effort and not a set point of angle?
Thanks
Nachum
Any idea?
