Run Gazebo headless on AWS and render locally with the gzclient
I installed gazebo on an AWS instance to run faster simulations. However, I am struggling with my setup. For doing a small test, I start an empty world on the AWS server
roslaunch gazebo_ros empty_world.launch headless:=true gui:=false
Then on my laptop I run:
ssh -L 11345:localhost:11345 ubuntu@aws_ip
this basically tunnels my localhost:11345 to the localhost:11345 of the aws computer. I then run
gzclient --verbose
on my laptop. The client starts, displays an empty gazebo window then dies.
Gazebo multi-robot simulator, version 9.0.0
http://gazebosim.org
[Msg] Waiting for master.
[Msg] Publicized address: 192.168.1.228
[Wrn] [Event.cc:61] Warning: Deleting a connection right after creation. Make sure to save the ConnectionPtr from a Connect call
[Wrn] [Publisher.cc:141] Queue limit reached for topic /gazebo/default/user_camera/pose, deleting message. This warning is printed only once.
terminate called after throwing an instance of 'boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::lock_error> >'
  what():  boost: mutex lock failed in pthread_mutex_lock: Invalid argument
Aborted (core dumped)
There is one minute or so between the first warning and the second one. What is the problem here? Was gazebo never meant to be run this way (with remote servers at least) Does the gzclient and the gzserver share so much data that it is not practical to do it through internet?
If so, what would be an alternative? I don't consider VNC to be an alternative as it probably will be quite laggy too
gzclient --verbose
internet? I checked with nethogs and gzclient barely pulls 40 KB/sec (way less than my internet bandwidth)
1679 mehdi    gzclient                wlp4s0      5.115      39.034 KB/sec
gzclient --verbose
There is one minute or so between the first warning and the second one. What is the problem here? Was gazebo never meant to be run this way (with remote servers at least) Does the gzclient and the gzserver share so much data that it is not practical to do it through internet? I checked with nethogs and gzclient barely pulls 40 KB/sec (way less than my internet bandwidth)
I am using Ubuntu 18.04 with ROS Melodic and Gazebo 9
