Inserted model changes it's pose automatically
Hello, I want to demonstrate pick and place in gazebo. For that i have created warehouse environment in gazebo.
I have converted 3D point clouds to meshes with the help of Meshlab and added the .dae mesh in Gazebo. I initially added the object to the gazebo and then saved the world as .sdf file and then i used previously saved world file to launch gazebo. In below image the white box you see is the object i want to pick.
image description
The problem is : When i launch gazebo and spawn the objects into it, the object changes it's pose automatically, I fetch the pose of the object by making a service call to gazebo/get_model_states and feed this pose to my pick place script. As object changes their position of this when i try to pick the object robot collides with the object.
Below is my model.sdf file for reference
<?xml version="1.0" ?>
<sdf version="1.5">
  <model name="kaffee">
      <pose>0 0 0.0175 0 0 0</pose>
        <mass>0.3</mass>
        <ixx>0.000234852</ixx>
        <ixy>0.0</ixy>
        <ixz>0.0</ixz>
        <iyy>0.000077182</iyy>
        <iyz>0.0</iyz>
        <izz>0.000273415</izz>
          <mesh>
        <uri>model://kaffee/meshes/kaffee.dae</uri>
      </mesh>
          <mesh>
          </mesh>
Can anyone tell how to make object stationary without making them static??
image description
I have already tried to use gazebo_msgs/set_model_pose service call to reset the object position after launching gazebo. Even after resetting position object change their position till the time robot reaches to grasp it.
<sdf version="1.5">
        <mass>0.3</mass>
        <ixy>0.0</ixy>
        <ixz>0.0</ixz>
        <iyz>0.0</iyz>
          <mesh>
      </mesh>
          <mesh>
          </mesh>
image description
The problem is : When i launch gazebo and spawn the objects into it, the object changes it's pose automatically, I fetch the pose of the object by making a service call to gazebo/get_model_states and feed this pose to my pick place script. As object changes their position when i try to pick the object robot collides with the object.
<sdf version="1.5">
        <mass>0.3</mass>
        <ixy>0.0</ixy>
        <ixz>0.0</ixz>
        <iyz>0.0</iyz>
          <mesh>
      </mesh>
          <mesh>
          </mesh>
