gazebo::physics::JointController::SetPositionTarget() memory consumption
 Hello!
I am using ***gazebo::physics::JointController::SetPositionTarget()*** Gazebo API method in order to control model joint positions. If I do it for long enough time Gazebo runs out of memory and terminates.
However, if I either dont call ***SetPositionTarget()*** or if I call it with one and the same argument all the time memory consumption doesn't grow.
I tried Gazebo7 and Gazebo9. The problem is the same.
I'd be very much obliged for any advice!
 Hello!
Hello!
I am using ***gazebo::physics::JointController::SetPositionTarget()*** gazebo::physics::JointController::SetPositionTarget() Gazebo API method in order to control model joint positions. If I do it for long enough time Gazebo runs out of memory and terminates. terminates.
However, if I either dont call ***SetPositionTarget()*** SetPositionTarget() or if I call it with one and the same argument all the time memory consumption doesn't grow. grow.
I tried Gazebo7 and Gazebo9. The problem is the same. same.
advice!
