my collision is not working
Hello everyone, I am new to gazebo, so I am not very familiar with gazebo.
My problem is about collision. I have put on <collision> tag in my urdf-file ( a hand model ), but the little finger still can run into my Palm. The following is my code, and I record the video. https://gist.github.com/pythongo1/11dea9ba511ab75edcfb4ea4eba161b3
This is the video.
https://youtu.be/rfyfUmKTd70
Thank you for your answer. Thanks.
My problem is about collision. I have put on <collision> tag in my urdf-file ( a hand model ), but the little finger still can run into my Palm. The following is my code, and I record the video. video.
This is the video.
My problem is about collision. I have put on <collision> tag in my urdf-file ( a hand model ), but the little finger still can run into my Palm. The following is my code, and I record the video.code.
This is the video.
My problem is about collision. I have put on <collision> tag in my urdf-file ( a hand model ), but the little finger still can run into my Palm. Palm.
The following is my code.
This is the video.
The following is my code.code. <link name="hand_base">
This is the video.
The following is my code. code.
<link name="hand_base">name="hand_base"> is my palm, <link name="finger5"> is the little finger's first part, <link name="finger5_1"> is the little finger's second part.
This is the video.
<link name="hand_base"> is my palm, <link name="finger5"> is the little finger's first part, <link name="finger5_1"> is the little finger's second part.
This is the video.
  <!-- real hand base -->
<link name="hand_base"> <visual> <origin xyz="0 0.061515 0" rpy="0 0 0"/> <geometry> <mesh filename="package://rrbot_description/meshes/hand_base_group_version8_final.dae" scale="1 1 1"/> </geometry> <material name="black"/> </visual>
<collision>
  <!-- for big a bit --> <!-- <box size="0.05 0.1 0.01"/> -->
  <origin xyz="0 0 0"/>
  <mass value="1"/>
  <inertia
  ixx="0.01" ixy="0.0" ixz="0.0"
  iyy="0.01" iyz="0.0"
  izz="0.01"/>
<joint name="hand_base_to_finger5" type="continuous"> <parent link="hand_base"/> <child link="finger5"/> <origin xyz="-0.03075 0.1099 -0.005841" rpy="0 ${2*PI/360*7} ${2*PI/360*6}"/>
<axis xyz="1 0 0"/>                    <!-- origin 1 0 0 -->
<limit effort="30" velocity="1"/>
<link name="finger5"> <visual> <origin xyz="0 0.019427 0"/> <geometry> <mesh filename="package://rrbot_description/meshes/finger5_shell.dae" scale="1 1 1"/> </geometry> <material name="black"/> </visual>
<collision>
    <!-- <box size="0.008 0.0355 0.008"/> -->
  <mass value="1"/>
  <inertia
  izz="0.01"/>
<joint name="finger5_to_finger5_1" type="continuous"> <parent link="finger5"/> <child link="finger5_1"/> <origin xyz="0 0.0355 0" rpy="0 0 0"/>
<axis xyz="1 0 0"/>
<link name="finger5_1"> <visual> <origin xyz="0 0.017182 0" rpy="0 0 0"/> <geometry> <mesh filename="package://rrbot_description/meshes/finger5_end.dae" scale="1 1 1"/> </geometry> <material name="black"/> </visual>
<collision>
  <origin xyz="0 0.017182 0" rpy="0 0 0"/>   <!-- xyz="0 0.018125 0" no rpy -->
  </geometry>  <!-- <box size="0.008 0.03625 0.008"/> -->
  <mass value="1"/>
  <inertia
  izz="0.01"/>
This is the video.
    <collision>
   <mass value="1"/>
  <inertia
      <inertia ixx="0.01" ixy="0.0" ixz="0.0"
  ixz="0.0" iyy="0.01" iyz="0.0"
  iyz="0.0" izz="0.01"/>
</link> <joint name="hand_base_to_finger5" type="continuous"> <parent link="hand_base"/> <child link="finger5"/> <origin xyz="-0.03075 0.1099 -0.005841" rpy="0 ${2*PI/360*7} ${2*PI/360*6}"/>
${2*PI/360*6}"/>
</joint> <link name="finger5"> <visual> <origin xyz="0 0.019427 0"/> <geometry> <mesh filename="package://rrbot_description/meshes/finger5_shell.dae" scale="1 1 1"/> </geometry> <material name="black"/> </visual>
    <collision>
   <mass value="1"/>
  <inertia
</link> <joint name="finger5_to_finger5_1" type="continuous"> <parent link="finger5"/> <child link="finger5_1"/> <origin xyz="0 0.0355 0" rpy="0 0 0"/>
0"/>
    <axis xyz="1 0 0"/>
</joint> <link name="finger5_1"> <visual> <origin xyz="0 0.017182 0" rpy="0 0 0"/> <geometry> <mesh filename="package://rrbot_description/meshes/finger5_end.dae" scale="1 1 1"/> </geometry> <material name="black"/> </visual>
    <collision>
   <mass value="1"/>
  <inertia
This is the video.
    <visual>
    <collision>
      <mass value="1"/>
      <inertia ixx="0.01" ixy="0.0" ixz="0.0" iyy="0.01" iyz="0.0" izz="0.01"/>
    <axis xyz="1 0 0"/>
    <visual>
    <collision>
      <mass value="1"/>
    <axis xyz="1 0 0"/>
    <visual>
    <collision>
      <mass value="1"/>
This is the video.
The following is my code.code, and the bottom is the video.
    <visual>
    <collision>
      <mass value="1"/>
    <axis xyz="1 0 0"/>
    <visual>
    <collision>
      <mass value="1"/>
    <axis xyz="1 0 0"/>
    <visual>
    <collision>
      <mass value="1"/>
This is the video.
