Is there a floating joint in Gazebo?
URDF description of the robot allows to specify a 'floating' joint -- a joint with 6 degrees of freedom. But when the robot description gets translated into SDF, the floating joint is converted into fixed joint. Is there a way how to achieve a floating joint in Gazebo? I want to completely control the child link's movement with my plugin.
