How to install Gazebo 9 in melodic using "packages.ros.org" as repository
In the official gazebo website "http://gazebosim.org/tutorials?tut=install_ubuntu&cat=install" , the installation procedure from the repository "packages.osrfoundation.org" is given. BUt they have nowhere informed how to install it in ""packages.ros.org".
I am having trouble in installing gazebo from ""packages.osrfoundation.org" in my ROS Melodic + Ubuntu 18.04. Also in the official website (http://gazebosim.org/tutorials/?tut=ros_wrapper_versions#InstallingGazebo), it is written "do not use the osrfoundation repository.".
So, what is the proper procedure to install Gazebo9 from "packages.ros.org" repository for ROS melodic.
In the official gazebo website "http://gazebosim.org/tutorials?tut=install_ubuntu&cat=install" , (http://gazebosim.org/tutorials?tut=install_ubuntu&cat=install), the installation procedure from the repository "packages.osrfoundation.org" is given. BUt they have nowhere informed how to install it in ""packages.ros.org".
In the official gazebo website (http://gazebosim.org/tutorials?tut=install_ubuntu&cat=install), the installation procedure from the repository "packages.osrfoundation.org" is given. BUt But they have nowhere informed how to install it in ""packages.ros.org". from "packages.ros.org" repository.
In the official gazebo website (http://gazebosim.org/tutorials?tut=install_ubuntu&cat=install), the installation procedure from the repository "packages.osrfoundation.org" is given. But they have nowhere informed how to install it from "packages.ros.org" repository.
So, what is the proper procedure to install Gazebo9 from "packages.ros.org" "packages.ros.org" repository for ROS melodic.strong text
So, what is the proper procedure to install Gazebo9 from "packages.ros.org" repository for ROS melodic.strong text
