Simulator_gazebo (1.5) and ROS groovy
I'm trying out simulator_gazebo with groovy. I noticed that when I tried to add a turtlebot to a test world that observed errors (see below).
<?xml version="1.0" ?>
<sdf version="1.3">
  <world name="default">
    <physics type="ode">
      <gravity>0 0 0</gravity>
      <ode>
        <solver>
          <type>quick</type>
          <dt>0.001</dt>
          <iters>40</iters>
          <sor>1.0</sor>
        </solver>
        <constraints>
          <cfm>0.0</cfm>
          <erp>0.2</erp>
          <contact_max_correcting_vel>100.0</contact_max_correcting_vel>
          <contact_surface_layer>0.0</contact_surface_layer>
        </constraints>
      </ode>
    </physics>
      <uri>model://sun</uri>
    <!-- A ground plane -->
      <uri>model://turtlebot</uri>
      <pose>0 0 1 0 0 0</pose>
  </world>
Errors observed are:
Gazebo multi-robot simulator, version 1.5.0
Copyright (C) 2013 Open Source Robotics Foundation.
http://gazebosim.org
Msg Waiting for master
[ INFO] [1366299708.959245033]: waitForService: Service [/gazebo/set_physics_properties] has not been advertised, waiting...
Msg Publicized address: XX.YY.XX.YY
Warning [ODEPhysics.cc:201] Gravity vector is (0, 0, 0). Objects will float.
[ INFO] [1366299709.183638696]: waitForService: Service [/gazebo/set_physics_properties] is now available.
Error [Events.hh:141] Events::ConnectWorldUpdateStart is deprecated in v 1.5.0. Please use Events::ConnectWorldUpdateBegin
[ INFO] [1366299709.276198138]: Starting to spin physics dynamic reconfigure node...
Warning [Publisher.cc:130] Queue limit reached for topic /gazebo/default/pose/info, deleting message (only this warning is printed to the console, see the ~/.gazebo/gzserver.log and ~/.gazebo/gzclient.log files for future warnings).
Warning [Publisher.cc:130] Queue limit reached for topic /gazebo/default/diagnostics, deleting message (only this warning is printed to the console, see the ~/.gazebo/gzserver.log and ~/.gazebo/gzclient.log files for future warnings).
Warning [Publisher.cc:130] Queue limit reached for topic /gazebo/default/physics/contacts, deleting message (only this warning is printed to the console, see the ~/.gazebo/gzserver.log and ~/.gazebo/gzclient.log files for future warnings).
Changing the turtlebot to a create, these warnings do not appear. But adding a kinect or a camera to the create also causes 1 queue limit message to be shown.
<sdf version="1.3">
      <ode>
        <solver>
          <type>quick</type>
          <dt>0.001</dt>
          <iters>40</iters>
          <sor>1.0</sor>
        </solver>
        <constraints>
          <cfm>0.0</cfm>
          <erp>0.2</erp>
        </constraints>
      </ode>
    </physics>
  </world>
Errors Warnings observed are:
click to hide/show revision 3
clarification of why I posted this
I'm trying out simulator_gazebo with groovy. I noticed that when I tried to add a turtlebot to a test world that observed there were errors and warnings (see below).below). But it seems to be working.
<sdf version="1.3">
      <ode>
        <solver>
          <type>quick</type>
          <dt>0.001</dt>
          <iters>40</iters>
          <sor>1.0</sor>
        </solver>
        <constraints>
          <cfm>0.0</cfm>
          <erp>0.2</erp>
        </constraints>
      </ode>
    </physics>
  </world>
Warnings Response observed are:is:
What else should be tested?
