Revolute joint in Gazebo with gazebo_ros_control not working
It seems like we can't control revolute joints with gazebo_ros_control plugin.
The easiest way to reproduce it is to clone the gazebo_ros_demos repo and edit the rrbot.xacro by replacing the continuous joint with a revolute joint.
Then the control doesn't work anymore.
Has anybody succeeded in controlling revolute joints in gazebo ?
here is the part of the urdf I changed:
  <joint name="joint1" type="revolute">
    <parent link="link1"/>
    <child link="link2"/>
    <origin xyz="0 ${width} ${height1 - axel_offset}" rpy="0 0 0"/>
    <axis xyz="0 1 0"/>
    <limit effort="100" velocity="30" upper="-3.14" lower="3.14"/>
    <dynamics damping="0.7"/>
here is the part of the urdf I changed:changed (l.55-63 of rrbot.xacro):
    <axis xyz="0 1 0"/>
