Unable to install gazebo 9.13
To be able to use the actors with collision plugin I need install Gazebo 9.13. To do so it seems like I have to use the following command, based on this other issue:
sudo apt-get install gazebo9=9.13.0-1*
This doesn't appear to work for me however, despite working for the other author. I also tried to write the following command, as suggested by another issue, but without any luck:
sudo apt-get update && sudo apt-get install gazebo9=9.13.0-1*
Error message:
ros@ubuntu:~$ sudo apt-get install gazebo9=9.13.0-1*
[sudo] password for ros:
Reading package lists... Done
Building dependency tree
E: Version '9.13.0-1*' for 'gazebo9' was not found
What do I need in order to properly install this version of Gazebo?
