With URDF models, you can use robot_state_publisher
to have the joints published in tf
. Since this needs the <robot>
tag, it does not work with SDF models. If you try to roslaunch
for a SDF it would say
Could not find the 'robot' element in the xml file
Everything else works fine in gazebo but the state publisher dies
Is there any way I can use robot state publisher with SDF? Maybe include URDF into the SDF? Or specify the <robot>
tag in it somehow?
TL;DR:
I have found many other questions related to this question but none had a positive answer and most of them are more than 5 years old. However,
- This answer suggests that you can do anything with SDF that is possible in URDF.
- This question has an answer suggesting an alternative by having both URDF and SDF but it's an ugly solution
- There's this old unanswered question as well
I want to create a 6 wheeled robot model with two wheels having shock absorbers (prismatic joints with damping and spring actions). To my understanding, this cannot be done using URDF
