Confused with gazebo plugin path
So, when I use the plugin libgazebo_ros_multicamera.so, I was able to successfully get the images I want. However, I am trying to locate the path for libgazebo_ros_multicamera.so, so I looked to setup.sh and found that the GAZEBO_PLUGIN_PATH is: /usr/lib/x86_64-linux-gnu/gazebo-9/plugins
But when I go into this path, I can't find libgazebo_ros_multicamera.so. Are there any other place that libgazebo_ros_multicamera.so is located?
