Gazebo doesn't use GPU when run inside a container
Hi Everyone, I have set up a singularity container (Ubuntu 16.04, Ros Kinetic, Gazebo 7.16), and I am running it on an HPC(high performance computing cluster). Everything is set up, I have access to Nvidia libraries, I can run OpenGL apps, and I also have CUDA. However, the gzserver and gzclient process refuse to use the GPU. This means that my robot's laser and camera render is stuck to 2 and 7 Hz. Does anyone know how can I force it? It is notable that the gazebo uses the GPU when I run the container on my own PC with Ubuntu 20.04 as a host. Any suggestions are welcome.
