UDP: What is the right transport hint?
In the various tutorials and ROS documentation I have seen the following variants of hinting that UDP packets should be used. Which is correct?
jointStatesSo.transport\_hints = ros::TransportHints().unreliable();
atlasStateSo.transport\_hints = ros::TransportHints().reliable().tcpNoDelay(true)
jointStatesSo.transport\_hints = ros::TransportHints().unreliable().reliable().tcpNoDelay(true);
Thanks,
Chris
In the various tutorials and ROS documentation I have seen the following variants of hinting that UDP packets should be used. Which is correct?optimal for receiving the current AtlasStates message in DRCSIM?
On a side note, I am assuming the hand commands and states will switch to UDP as well?
What about IMU packets?
atlas_msgs/AtlasSimInterfaceState? atlas_msgs/AtlasSimInterfaceCommand?
controller_statistics?
clock messages?
Image transport? stereo proc messages?
laser spindle joint states?
laser scans?
Thanks,
Chris
In the various tutorials and ROS documentation I have seen the following variants of hinting that UDP packets should be used. Which is optimal for receiving the current AtlasStates message in DRCSIM?
jointStatesSo.transport\_hints jointStatesSo.transport_hints = ros::TransportHints().unreliable();
atlasStateSo.transport\_hints atlasStateSo.transport_hints = ros::TransportHints().reliable().tcpNoDelay(true)
jointStatesSo.transport\_hints jointStatesSo.transport_hints = ros::TransportHints().unreliable().reliable().tcpNoDelay(true);
clock messages?
laser scans?
Thanks,
Chris
