Contact sensor plugin not working
Hello, I am trying to add a contact sensor to my robotic arm tool to be able to detect its collision with external parts. I tried to follow the tutorial proposed here . When I run my gazebo project, I find the desired gazebo topic but It does not display the collisions.
I added the contact sensor to my .urdf as follows:
  <gazebo reference="tool0">
        <sensor name='my_contact' type='contact'>
         <update_rate>10</update_rate>
        <plugin name="my_plugin" filename="libcontact.so"/>
    <contact>
                <collision>tool_collision</collision>
        </contact>
and my plugin is as follows:
ContactPlugin.hh
#ifndef _GAZEBO_CONTACT_PLUGIN_HH_
#define _GAZEBO_CONTACT_PLUGIN_HH_
#include <string>
#include <gazebo/gazebo.hh>
#include <gazebo/sensors/sensors.hh>
namespace gazebo
  /// \brief An example plugin for a contact sensor.
  class ContactPlugin : public SensorPlugin
    /// \brief Constructor.
    public: ContactPlugin();
    /// \brief Destructor.
    public: virtual ~ContactPlugin();
    /// \brief Load the sensor plugin.
    /// \param[in] _sensor Pointer to the sensor that loaded this plugin.
    /// \param[in] _sdf SDF element that describes the plugin.
    public: virtual void Load(sensors::SensorPtr _sensor, sdf::ElementPtr _sdf);
    /// \brief Callback that receives the contact sensor's update signal.
    private: virtual void OnUpdate();
    /// \brief Pointer to the contact sensor
    private: sensors::ContactSensorPtr parentSensor;
    /// \brief Connection that maintains a link between the contact sensor's
    /// updated signal and the OnUpdate callback.
#endif
and
PluginContact.cc
#include "ContactPlugin.hh"
using namespace gazebo;
GZ_REGISTER_SENSOR_PLUGIN(ContactPlugin)
ContactPlugin::ContactPlugin() : SensorPlugin()
ContactPlugin::~ContactPlugin()
void ContactPlugin::Load(sensors::SensorPtr _sensor, sdf::ElementPtr /*_sdf*/)
  // Get the parent sensor.
  this->parentSensor =
    std::dynamic_pointer_cast<sensors::ContactSensor>(_sensor);
  // Make sure the parent sensor is valid.
  if (!this->parentSensor)
    gzerr << "ContactPlugin requires a ContactSensor.\n";
    return;
  // Connect to the sensor update event.
  this->updateConnection = this->parentSensor->ConnectUpdated(
      std::bind(&ContactPlugin::OnUpdate, this));
  // Make sure the parent sensor is active.
  this->parentSensor->SetActive(true);
void ContactPlugin::OnUpdate()
  // Get all the contacts.
  msgs::Contacts contacts;
  contacts = this->parentSensor->Contacts();
  for (unsigned int i = 0; i < contacts.contact_size(); ++i)
    std::cout << "Collision between[" << contacts.contact(i).collision1()
              << "] and [" << contacts.contact(i).collision2() << "]\n";
    for (unsigned int j = 0; j < contacts.contact(i).position_size(); ++j)
      std::cout << j << "  Position:"
                << contacts.contact(i).position(j).x() << " "
                << contacts.contact(i).position(j).y() << " "
                << contacts.contact(i).position(j).z() << "\n";
      std::cout << "   Normal:"
                << contacts.contact(i).normal(j).x() << " "
                << contacts.contact(i).normal(j).y() << " "
                << contacts.contact(i).normal(j).z() << "\n";
      std::cout << "   Depth:" << contacts.contact(i).depth(j) << "\n";
when I reand the target link contact through the command
gz topic -e /gazebo/default/robot/tool0/my_contact/contacts
All what I obtain is info about simulation time. Here an example
time {
  sec: 332
  nsec: 996000000
Can you please tell what can be the problem???? I am so thankful
