Getting sonar sensor data into model plugin
Hi, This is my first question here. Pardon me for any mistakes.
I have spent some time looking this over the internet but could not find a working solution yet. Documentation doesn't have much on Sonar sensors..
I am trying to read the sonar sensor range values which the sensor plugin, SonarPlugin.cc gives me and publishes to the topic /gazebo/mtp_world/mtp_robot/left_sonar/mtp_sonar_sensor_left/sonar in the robot's model plugin, move_bot.cc using a transport node and a subscriber
I got this topic from gz topic -l and doing gz topic -e <this-topic-name> gives the required range outputs along with other sonar values.
I have a very basic understanding of topics work. The message returned from the subscriber is NULL for this topic.
Here are the relevant code snippets:
    class MoveBot : public ModelPlugin {
        private: physics::WorldPtr world;
        private: physics::JointPtr leftJoint;
        private: physics::JointPtr rightJoint;
        private: common::Time startTime;
        private: transport::SubscriberPtr sub;
        public: void Load(physics::ModelPtr _parent, sdf::ElementPtr /* _sdf */) {
            this->model = _parent;
            this->world = this->model->GetWorld();
            this->leftJoint = this->model->GetJoint("left_wheel_hinge");
            this->rightJoint = this->model->GetJoint("right_wheel_hinge");
            transport::NodePtr node(new transport::Node());
            node->Init();
            this->sonarTopicLeft =
                "/gazebo/mtp_world/mtp_robot/left_sonar/mtp_sonar_sensor_left/sonar";
            this->sub = node->Subscribe(this->sonarTopicLeft, &MoveBot::cb, this);
            this->updateConnection =
                event::Events::ConnectWorldUpdateBegin(std::bind(&MoveBot::OnUpdate, this));
        private: void cb(ConstSonarPtr &_msg) {
            std::cout<< "callback!!!!!!!" << std::endl;
            if (_msg == NULL) {
                std::cout<< "NULL!!!!!!!" << std::endl;
                return;
            std::cout << "Message: " << _msg->range() << std::endl;
        private: void onUpdate() {
            // Some other code
I am expecting the cb(ConstSonarPtr &_msg) callback to print the range values but I only get NULL!!!!!!! printed.
Any help would be greatly appreciated! Thank you.
Getting Reading sonar sensor data into in model plugin
            node->Init();
            if (_msg == NULL) {
                return;
            // Some other code
Reading sonar sensor data in model plugin
            node->Init();
            if (_msg == NULL) {
                return;
            // Some other code
