Properly making soft joints to world in Gazebo 9 + ROS Melodic
I'm trying to interact a position-controlled robot with "fixed" obstacles in its environment. In this case, they're a couple of floating spheres, "magically" fixed in space. I'm using default ros-melodic-desktop-full installations to do this, in this case Gazebo 9.13.1 on Windows.
With <static> obstacles and default constraint parameters, the robot "explodes" if it touches obstacles. This is reasonable behavior given the incompatible constraints of infinitely rigid object meets immovable object.
If I add some global constraint force mixing with <cfm> tags at world->physics scope, it stabilizes the simulation and makes the robot's contacts with the world understandable, but it also allows the joints to slide apart. This is also correct behavior from the standpoint of what CFM does, but it's not the desired behavior.
What I'd like to do is attach the floating spheres to the world frame using spring-dampers that are much softer than the robot joints, so that they easily slide out of the way if the robot collides without pulling the robot joints apart visibly.
I'm having a very hard time finding a correct and complete description on how to do this, partially because any suggestions are scattered across many years of SDF file format changes, unanswered ROS Answers and Gazebo Answers questions, and so on.
I have successfully held the spheres in place with fixed joints so they move a little with relaxed constraints. After a long time experimenting (because of lack of a complete example) I figured out I could put those joints in a nested <model> so I could write this "boundary condition" in my world file instead of the complex model file that defines the visual/inertial/collision geometry.
Now I'd like to soften the joints that hold the spheres in place. So I'm trying to set different <cfm> and <erp> values for the spheres' fixed joints, or maybe <implicit_spring_damper> or ... what? Everything I've tried has resulted in the spheres' displacements being the same order of magnitude as the robot's displacement.
image description
I still can't find a documentation source that's any more useful than http://sdformat.org/spec?elem=joint&ver=1.5, but that just kind of tells me which tags I might try, not how they fit together.
The image was captured using these settings for the red sphere:
<model name="soft_fixed_big_red">
    <uri>model://big_red</uri>
    <name>red_sphere</name>
  <joint name="bc" type="fixed">
    <parent>world</parent>
    <child>red_sphere::link</child>
    <physics>
      <ode>
        <implicit_spring_damper>1</implicit_spring_damper>
        <cfm>0.9</cfm>
        <erp>0.2</erp>
      </ode>
      <provide_feedback>true</provide_feedback>
    </physics>
  <pose>0.15 0.50 0.45 0 0 0</pose>
The spheres had mass properties like solid plastic when I started. I tried making them thin, extremely light spherical shells, which made it shakier but roughly similar in relative sphere and robot displacements.
At the world level (which contains the red and blue sphere models, ground plane, and sun), I have this:
<physics name="test_default" type="ode">
  <real_time_update_rate>1000</real_time_update_rate>
  <ode>
    <constraints>
      <cfm>0.001</cfm>
      <erp>0.2</erp>
    </constraints>
  </ode>
</physics>
I'll keep working on it and write the findings here.
Please let me know if this just isn't possible in Gazebo 9 or something, or if I'm making a conceptual error (global cfm overriding joint cfm? Missing tags and quiet errors?)
Thanks!
