Continuing the question from https://community.gazebosim.org/t/not-able-to-simulate-my-sdf-file-in-ignition-gazebo/813
I was trying to simulate an animal(file attached below) in ignition gazebo by adding it to the empty_world.sdf file as explained in the tutorial https://ignitionrobotics.org/docs/citadel/sdf_worlds#sdf-worlds.
The error I am getting is given below
[Err] [Server.cc:181] Error Code 13 Msg: Directory doesn’t exist[goat.dae]
[GUI] [Err] [PathManager.cc:57] Service call timed out for [/gazebo/resource_paths/get]
The code I used
<?xml version="1.0" ?>
<sdf version="1.7">
<world name="world_demo">
<physics name="1ms" type="ignored">
<max_step_size>0.001</max_step_size>
<real_time_factor>1.0</real_time_factor>
</physics>
filename="libignition-gazebo-physics-system.so"
name="ignition::gazebo::systems::Physics">
filename="libignition-gazebo-user-commands-system.so"
name="ignition::gazebo::systems::UserCommands">
filename="libignition-gazebo-scene-broadcaster-system.so"
name="ignition::gazebo::systems::SceneBroadcaster">
<gui fullscreen="0">
<!-- 3D scene -->
<plugin filename="GzScene3D" name="3D View">
<ignition-gui>
<title>3D View</title>
<property type="bool" key="showTitleBar">false</property>
<property type="string" key="state">docked</property>
</ignition-gui>
<engine>ogre2</engine>
<scene>scene</scene>
<ambient_light>1.0 1.0 1.0</ambient_light>
<background_color>0.8 0.8 0.8</background_color>
<camera_pose>-6 0 6 0 0.5 0</camera_pose>
<!-- World control -->
<plugin filename="WorldControl" name="World control">
<ignition-gui>
<title>World control</title>
<property type="bool" key="resizable">false</property>
<property type="double" key="height">72</property>
<property type="double" key="width">121</property>
<property type="double" key="z">1</property>
<property type="string" key="state">floating</property>
<anchors target="3D View">
<line own="left" target="left"/>
<line own="bottom" target="bottom"/>
</anchors>
</ignition-gui>
<play_pause>true</play_pause>
<step>true</step>
<start_paused>true</start_paused>
<service>/world/world_demo/control</service>
<stats_topic>/world_demo/world_demo/stats</stats_topic>
<!-- World statistics -->
<plugin filename="WorldStats" name="World stats">
<ignition-gui>
<title>World stats</title>
<property type="double" key="height">110</property>
<property type="double" key="width">290</property>
<line own="right" target="right"/>
</anchors>
</ignition-gui>
<sim_time>true</sim_time>
<real_time>true</real_time>
<real_time_factor>true</real_time_factor>
<iterations>true</iterations>
<topic>/world/world_demo/stats</topic>
<!-- Entity tree -->
<plugin filename="EntityTree" name="Entity tree">
</gui>
<!--light-->
<light type="directional" name="sun">
<cast_shadows>true</cast_shadows>
<pose>0 0 10 0 0 0</pose>
<diffuse>0.8 0.8 0.8 1</diffuse>
<specular>0.2 0.2 0.2 1</specular>
<attenuation>
<range>1000</range>
<constant>0.9</constant>
<linear>0.01</linear>
<quadratic>0.001</quadratic>
</attenuation>
<direction>-0.5 0.1 -0.9</direction>
</light>
<uri>
model://goat.dae
</uri>
</world>
ignition gazebo version I am using
Ignition Gazebo, version 4.2.0
Copyright (C) 2018 Open Source Robotics Foundation.
Released under the Apache 2.0 License.
Note: I tried adding the file to my workspace ~/ign-gazebo/examples/worlds but it still didn't work. I am able to simulate all the other files.
Thanks
