DRC robot doesn't move repeatably between runs
Extracted from question 2665
When executing certain movement based commands, the atlas robot does not perform the same action any two times in a row even though it has been specifically told to perform the same thing it just did last simulation. For example, if you tell atlas to turn by x degrees, and then stand still, atlas might do the following:
  • Trial 1) Actually Turn X degrees and Successfully Stand Still
  • Trial 2) Actually Turn X degrees and fall to the right
  • Trial 3) Actually Turn X degrees and fall forward
  • Trial 4) Turn Y Degrees and fall backward
  • Trial 5) Turn Y Degrees and fall to the left
  • Trial 1) Actually Turn X degrees and and Successfully Stand Still
  • Trial 2) Actually Turn X degrees and fall to to the right
  • Trial 3) Actually Turn X X degrees and fall forward
  • Trial 5) Turn Y Degrees and fall to to the left
DRC robot doesn't move repeatably between runsfalls when rotating in place
