Ogre::FileNotFoundException (shadow_receiver.program) after update the simulator_gazebo stack on Fuerte
I'm using Fuerte on Ubuntu 11.10 and to fix the contact sensor bug I created an overlay for the simulator _ gazebo stack using the latest tag (I did a "svn to https://code.ros.org/svn/ros-pkg/stacks/simulator_gazebo/tags/simulator_gazebo-1.7.6/") in a directory that's in my ROS _ PACKAGE _ PATH (as explained here: https://bitbucket.org/osrf/gazebo/issue/13/contactsensor-in-gazebo-fuerte),
but now when I launch the empty_world I get this error:
Msg Connected to gazebo master @ http://localhost:11345
terminate called after throwing an instance of 'Ogre::FileNotFoundException'
what():  OGRE EXCEPTION(6:FileNotFoundException): Cannot locate resource shadow_receiver.program
in resource group General or any other group. in ResourceGroupManager::openResource at
/tmp/buildd/ros-fuerte-visualization-common-1.8.4/debian/ros-fuerte-visualization-common/opt/ros/fuerte/stacks/visualization_common/ogre/build/ogre_src_v1-7-3/OgreMain/src/OgreResourceGroupManager.cpp (line 753)
Aborted
How can I fix it?
Thanks, Giacomo.
