I found this from http://sdformat.org/spec?ver=1.9&elem=geometry
I wanted to try this out on Citadel and Fortress so I did a simple section:
<model name='test'> <link name = "test_shape"> <pose>0 0 0 0 0 0 </pose> <visual name="'visual"> <geometry> <polyline> <point> 1 1</point> <height> 5</height> </polyline> </geometry> </visual> <collision name="collision"> <geometry> <polyline> <point> 1 1</point> <height> 5</height> </polyline> </geometry> </collision> </link> </model>
Yet it created multiple errors:
bwuk@robots:~/smart-car/simulation/model/sdf$ ign gazebo -r test.sdf
Warning [GenericJoint.hpp:1480] [GenericJoint::setRestPosition] Value of _q0 [0], is out of the limit range [0.1, 3.1] for index [0] of Joint [Joint].
[Err] [Conversions.cc:245] Geometry type [0] not supported
Error [parser.cc:796] Error parsing XML from string: Error=XML_ERROR_PARSING_ATTRIBUTE ErrorID=8 (0x8) Line number=4: XMLElement name=visual
[GUI] [Err] [Model.hh:73] Unable to unserialize sdf::Model
[GUI] [Err] [Conversions.cc:360] Geometry type [0] not supported
[Err] [SceneManager.cc:739] Unsupported geometry type
[Err] [SceneManager.cc:393] Failed to load geometry for visual: 'visual
[GUI] [Err] [SceneManager.cc:739] Unsupported geometry type
[GUI] [Err] [SceneManager.cc:393] Failed to load geometry for visual: 'visual
I even ran ign sdf --check test.sdf
and it returns Valid.
So...what did I do wrong? How do you use polyline in ignition?
I hope this is not bug since I already created more than 10 issues in Github already lol :'(
