Is there a way to use model's name as a reference for a plugin's topic? (Citadel or Fortress)
For example, the current section:
     <sensor name='gpu_lidar' type='gpu_lidar'>
      <topic>ultrasonic0</topic>
      <update_rate>20</update_rate>
This doesn't have to be gpu_lidar only. It can be joint_controller, battery or any plugin type.
So, the topic will be displaying as /ultrasonic0, right?
So, is there a way to do like this: /<model_name_from_file>/ultrasonic0?
I wanted to duplicate robots in future along with rename set as true in the same world so I was hoping like
/robot_00/ultrasonic0 /robot_01/ultrasonic0 /robot_02/ultrasonic0
And so on.
Is this possible? I tried <namespace> and <topic></topic> but it end up an absolute path which I don't want that.
