I want to use a camera in Gazebo & used the model from https://github.com/osrf/gazebo_models. I changed the pose of the camera in its sdf file as follows (& saved it):
<pose>0 0 0.5 0 1.5708 1.5708</pose>
But, if I launch gazebo & insert the camera model from GUI & check its properties, I see different roll, pitch & yaw:
What is happening here?
P.S: 1) I'm using Gazebo11
P.S: 2) This is my camera's sdf file(I'm using a plugin to read camera feed in ROS):
<?xml version="1.0" ?>
<sdf version="1.5">
<model name="camera">
<gravity>0</gravity>
<mass>0.1</mass>
<ixx>1.000166667</ixx>
<iyy>1.000166667</iyy>
<izz>1.000166667</izz>
<sensor name="camera" type="camera">
<width>320</width>
<height>240</height>
<far>100</far>
<plugin name="camera_controller" filename="libgazebo_ros_camera.so">
<alwaysOn>true</alwaysOn>
<updateRate>0.0</updateRate>
<cameraName>free_camera</cameraName>
<imageTopicName>/free_camera/image_raw</imageTopicName>
<cameraInfoTopicName>/free_camera/camera_info</cameraInfoTopicName>
<frameName>camera_link</frameName>
<hackBaseline>0.07</hackBaseline>
<distortionK1>0.0</distortionK1>
<distortionK2>0.0</distortionK2>
<distortionK3>0.0</distortionK3>
<distortionT1>0.0</distortionT1>
<distortionT2>0.0</distortionT2>
