gazebo_ros_control plugin is waiting for model URDF in parameter [/robot_description] on the ROS param server
Hi guys, trying to simulate a kuka iiwa in gazebo11 with Ubuntu 20 and ROS noetic. I get the following output after I roslaunch iiwa_gazebo iiwa.launch output
So it never loads the gazebo_ros plugin. I can't figure out why. These are the contents of the log file:
log file
I have attached the launch file C:\fakepath\iiwa.launch and sdf file C:\fakepath\iiwa7_no_collision.sdf
If anyone can help, it would be much appreciated :) Thank you guys so much!
