I'm not quite familiar with this. Do you know how to use ignition.msgs in command line? I was following this doc
using EntityFactory which is ignition.msgs.EntityFactory
in command line. I wanted to clear sensors to 0 so I used SENSOR
or Clear()
So I tried many ways include
ign service -s /world/free_world/create --reqtype ignition.msgs.EntityFactory --reptype ignition.msgs.Boolean --timeout 300 --req 'clear'
ign service -s /world/free_world/create --reqtype ignition.msgs.EntityFactory --reptype ignition.msgs.Boolean --timeout 300 --req 'clear: true'
ign service -s /world/free_world/create --reqtype ignition.msgs.EntityFactory --reptype ignition.msgs.Boolean --timeout 300 --req 'clear = true'
None of them worked. Error just returns like this,
[libprotobuf ERROR google/protobuf/text_format.cc:307] Error parsing text-format ignition.msgs.EntityFactory: 1:7: Message type "ignition.msgs.EntityFactory" has no field named "clear".
I wanted to do this because of respawn. This sensor is actually prevent the respawn due to error where it says camera rgb is already exist in entity [#]. I explained more in github but then I realized, this is just belong to this site
Last question, do you know if there's any documentation or tutorial for this one?
