Ubuntu 22.04 and Gazebo Classic not working
I upgraded Ubuntu 20.04 to the 22.04 version. I installed ROS2 Humble (sudo apt install ros-humble-desktop-full) and I wanted to use Gazebo Classic with Nav2 simulations, but I cannot use it - my packages have unmet dependencies, that I couldn't fix. Please hint me what I should do now.
My terminal logs:
  • When I tried normal sudo apt install gazebo:
ljaniec@ljaniec-PC:~$ gazebo
Command 'gazebo' not found, but can be installed with:
ljaniec@ljaniec-PC:~$ sudo apt install gazebo
Reading package lists... Done
Building dependency tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 gazebo : Depends: libgazebo11 (= 11.10.2+dfsg-1) but 11.12.0-1~focal is to be installed
E: Unable to correct problems, you have held broken packages.
  • When I tried sudo apt install ros-humble-gazebo-ros-pkgs:
ljaniec@ljaniec-PC:~$ sudo apt install ros-humble-gazebo-ros-pkgs
 gz-tools2 : Conflicts: gazebo (>= 11.0.0) but 11.10.2+dfsg-1 is to be installed
 libgazebo-dev : Depends: libgazebo11 (= 11.10.2+dfsg-1) but 11.12.0-1~focal is to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
ljaniec@ljaniec-PC:~$ sudo apt install libgazebo11
libgazebo11 is already the newest version (11.12.0-1~focal).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Best Ɓukasz
