Publish message from the command line
I am trying to send a cmd_pos message using the command line. The type of the message is igntion::msgs::Double. I am using the command
ign topic -t "world/empty/model/simple-robot/joint/the_joint/cmd_pos" -p "1.3" --msgtype ignition::msgs::Double`
instead of "1.3", I also tried 1.3, data: 1.3, {data: 1.3}, and more. But I keep getting the message
Unable to create message of type[ignition::msgs::Double] with data[...]
with my value for p on the ....
How can I send a Double message using the command line?
