ros-ign-bridge not publishing CameraInfo
Hi I'm using Gazebo Fortress compiled from sources on Ubuntu 20.04 with ROS Noetic
When running roslaunch ros_ign_gazebo_demos rgbd_camera_bridge.launch
If I add a Camera view in RViz I get the warning CameraInfo not published.
Is this considered a normal behavior?
If not, how can I fix this?
EDIT: I've figured out the following: In the Gazebo GUI, add the Image Display plugin, then select the depth image. The message will then be published on the associated Gazebo topic.
My question now is how to get the data to be published without using the GUI.
My question now is how to is: How do I get the data to be published without using the GUI.GUI?
