Inverse kinematics for Atlas Arm?
Hi All. I am trying to find out the Inverse Kinematic solution for the Atlas Arm. I am trying to use the 'arm_kinematics' package for this. The steps I used for this are as follows:
I entered the following commands in seperate terminals:
  1. roslaunch urdf_tutorial display.launch model:=atlas_sandia_hands.urdf
  2. roslaunch atlas_utils atlas_sandia_hands.launch
In a separate terminal I entered the following commands:
  1. rosparam set urdf_xml robot_description
  2. rosparam set robot_description atlas_sandia_hands.urdf
  3. rosparam set arm_kinematics/root_name utorso
  4. rosparam set arm_kinematics/tip_name l_hand
  5. rosparam set maxIterations 1000
  6. rosrun arm_kinematics arm_kinematics
Then I wrote a python script for finding out the IK solution. I tried following the tutorial for PR2 arm inverse kinematics. This is what I had:
! /usr/bin/env python
import roslib; roslib.load_manifest('tutorial_atlas_control') roslib.load_manifest('geometry_msgs') roslib.load_manifest('kinematics_msgs')
import rospy, yaml, sys from atlas_msgs.msg import AtlasCommand from sensor_msgs.msg import JointState from std_msgs.msg import * from geometry_msgs.msg import * from kinematics_msgs.srv import * from arm_navigation_msgs.srv import *
class findik:
def get_ik(self, x, y, z):
    rospy.init_node('find_ik')
    self.ik_info = '/arm_kinematics/get_ik_solver_info'
    print "waiting for ik service"
    rospy.wait_for_service(self.ik_info)
    self.ik_info_service = rospy.ServiceProxy(self.ik_info, GetKinematicSolverInfo)
    self.ik_info_service.joint_names = ["l_arm_usy",
                                        "l_arm_shx",
                                        "l_arm_ely",
                                        "l_arm_elx",
                                        "l_arm_uwy",
                                        "l_arm_mwx"]
    self.ik_info_service.joint_names = ["utorso",
                                        "l_clav",
                                        "l_scap",
                                        "l_uarm",
                                        "l_larm",
                                        "l_farm",
                                        "l_hand"]
    self.ik_info_req = GetKinematicSolverInfoRequest()
    self.ik_info_res = self.ik_info_service.call(self.ik_info_req)
    self.ik_service = rospy.ServiceProxy('arm_kinematics/get_ik', GetPositionIK, True)
    self.ik_req = GetPositionIKRequest()
    self.ik_req.timeout = rospy.Duration(5.0)
    self.ik_req.ik_request.ik_link_name = 'l_hand'
    self.ik_req.ik_request.ik_seed_state.joint_state.name = self.ik_info_res.kinematic_solver_info.joint_names
    self.ik_req.ik_request.ik_seed_state.joint_state.position = [0]*6
    self.ps = PoseStamped()
    self.ps.header.stamp = rospy.Time(0)
    self.ps.header.frame_id = 'pelvis'
    self.ps.pose.position.x = x
    self.ps.pose.position.y = y
    self.ps.pose.position.z = z
    self.ps.pose.orientation.x = 0
    self.ps.pose.orientation.y = 0
    self.ps.pose.orientation.z = 0
    self.ps.pose.orientation.w = 1.0
    self.ik_req.ik_request.pose_stamped = self.ps
    self.ik_res = self.ik_service.call(self.ik_req)
if __name__ == '__main__': ik = findik() ik.get_ik(0.55, -0.15, 1.2)
However the command "self.ik_res = self.ik_service.call(self.ik_req)" would result in rospy exception and would stop the "arm_kinematics" node in the other terminal.
Has any one tried finding IK for Atlas. What Package did you use. If you used "arm_kinematics" did you run into similar problem?? Please let me know. I am using ros Fuerte, Gazebo 1.8.2 and drcsim 2.6.6.1 in ubuntu 12.04.
Any help will be highly appreciated. Thanks.
class findik:
                                        "l_arm_shx",
                                        "l_arm_ely",
                                        "l_arm_elx",
                                        "l_arm_uwy",
                                        "l_arm_mwx"]
                                        "l_clav",
                                        "l_scap",
                                        "l_uarm",
                                        "l_larm",
                                        "l_farm",
                                        "l_hand"]
import roslib; roslib roslib.load_manifest('tutorial_atlas_control') roslib.load_manifest('geometry_msgs') roslib.load_manifest('kinematics_msgs')
class findik:
                                        "l_arm_shx",
                                        "l_arm_ely",
                                        "l_arm_elx",
                                        "l_arm_uwy",
                                        "l_arm_mwx"]
                                        "l_clav",
                                        "l_scap",
                                        "l_uarm",
                                        "l_larm",
                                        "l_farm",
                                        "l_hand"]
import roslib roslib.load_manifest('tutorial_atlas_control') roslib.load_manifest('geometry_msgs') roslib.load_manifest('kinematics_msgs')
class findik:
                                        "l_arm_shx",
                                        "l_arm_ely",
                                        "l_arm_elx",
                                        "l_arm_uwy",
                                        "l_arm_mwx"]
                                        "l_clav",
                                        "l_scap",
                                        "l_uarm",
                                        "l_larm",
                                        "l_farm",
                                        "l_hand"]
